Hi guys,
I've looked at existing threads on servicing the V's...but my query relates specifically to the V36 370 - hence why I am starting a new thread.
A friend of mine wants to buy a V36 370 S model (coupe, auto, 2007/8). He is concerned about servicing costs and practicality.
Please note - he has no mechanical aptitude, does not want to be self-servicing, or even having to source parts. He'd like to think that he can rock up to Nissan dealership or Ultratune (or similar) and get the car serviced.
Given the stipulations of the V36 370 service schedule - is this a realistic expectation?
can any members who do or have owned the V36 370 coupe speak directly with regards to their personal experiences? What I would like to know is;
1. Is servicing the Skyline essentially the same as the 370Z – in terms of who can do it, what it costs, parts required etc
2. Is the ECU the same (by and large) as what is in the 370Z – such that a ‘normal garage’ could tune it?
3. Could servicing be done by (say) Nissan, or Ultratune, or an average mechanic
For reference, my friend lives in Traralgon – so a big country town, with Nissan dealership and Ultratune, but no performance workshops nearby.
Any assistance would be appreciated.
Cheers,
Foibles
Same engine as 370z
Nissan dealership can service them if they want to but alot of them will say they won't touch an import. You can tell them to just follow the service schedule for 370z.
One thing I've found different is that the 350z and 370z is the throttle body is different to the Vs...but in Japan and America they are suppose to be the same.
That said the ECU in Japan and America has the same ECU for the V/G and Z. Tuning can be done only with a reflash. Uprev is a popular reflash people use.
If go with specialist to service the car.
1). Yes
2). Almost all Nisan dealers won't touch a V35/V36 with a 20 foot pole - they HATE grey imports.
3). as mentioned you cannot 'tune' the stock ECU - if you get a Cobb or Osiris unit you can reflash the ECU, but you really need a local tuner skilled with Skylines to do this.
But the basic servicing any idiot can do - drop the oil then refill, clean the air filter element, top up the coolant. That's about all you need to do in terms of regular maintenance.
As mentioned, you don't 'tune' a car these days as part of a regular service, like you did in the old days of carburetors, points and weight type advance. These days they just check the ecu for any fault codes during a regular service.
Given they are essentially the same as the G37 being brought in by Nissan Australia, I'd say there shouldn't be any need to draw parallels with the 370Z any longer as the dealerships (those who will touch a grey import) will be trained to know these vehicles as well, I would think.
Get your friend to do the homework and if he isn't confident in servicing the vehicle himself or he can't find anyone reliable in his country town, then tell him to either take the risk or find something else. Otherwise, as already mentioned, any idiot can drop the oil, replace the filter and spark plugs where necessary - once you show them. Be sure he stocks up on copper crush washers for the oil sump drain plug as it's wise to replace that washer with every service.
Repco service agents, if they can be bothered, can access the Repco NZ files that cover the servicing and parts for Imports. The local one in Berwick did, when I had my R33 and the one in Officer needed NZ files for the M35 for brake specs etc. when they did my roadworthy.
There is nothing hard about maintianing or servicing a 370GT, all the consumable parts (filters, brake pads etc) are available from ryco, bendix or nissan. Any compident mechainical shop should have no trouble with this car.
  • 3 weeks later...
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
