Hey guys,
Got a r33 which I've stripped down n put some basic bolt on mods to, greddy copy plenum, garret 35r ext gate, running a nistune chipped ecu (rb20?) FMIC n all the rest of the usual goods to support injectors, pump n z32 afm ect.
Have started the engine (with rb25 ecu and stock fuel system to check it runs and for leaks ect before it goes on the dyno n costs me a shitload in leak repairs ect, all was fine) and now have installed the injectors, afm and pump to the motor, i would like to get a few people's thoughts on A FEW WORKSHOPS/TUNERS that tune nistune, thanks guys
Gav.
Id ditch the nistune for the 33 mate my car never ran quite perfect with it plus using the RB20 ecu stops you using VCT from memory which you will want if ya running a GT35. Mine was a Z32 ECU. Id recommend picking up a power fc on the cheap if you can. If you got a bit of coin to splash out get a link G4 my car ran awesome with the link. Tuner I would recommend is unigroup engineering at Girraween :)
Cheers guys,
Interesting, I'm pretty clueless in regards to the ecu Side of things so thought I'd come on here n ask,
Don't you lose VCT anyway once cams/vernier gears are installed tho?
(Which I had forgot to list, my f**k up lol) I've heard good reviews about yavuz at UNI group.
If I was to run a stock engine with the rb20 ecu how would one wire the switch?
Thanks
Should have kept the VCT...
Nistune is fine if if you want something a bit cheaper. But you have a to source an RB20 ECU and then put a Nistune board in it. Not hard. As you don't have VCT anymore you don't need a VCT switch or a Z32 ECU.
Power FC's are good for people who just want a tuneable ECU that is plug and play.
Link ECU = Stupidly awesome ECU with so many features (depending on which type you go with). But the cost tag is up there for a lot of people. They do plug and play models as well as a full wire in. Full wire in is always a better install as you get rid of the shitty 20 year old wiring loom.
I'm not from NSW, but JEM is quite good?
@ kitto
Yeah I got my hands on a old mates rb20 ecu with the board for next to nothing hey, I suppose if I had my time again is go a pfc or link, I might go see how it goes when I speak to the tuner n get there opinion also before I make the call hey, I appreciate the help guys, might find myself on here a bit more, lots of good info n good people on here..
The g4 is a sweet bit of kit tho, friends got one on his 32, goes like a rocket!
@ micko
As it's a toy not my daily + it's just a bit of fun I'd like to keep it lower the better but obviously you get what you pay for,
Not poncams, there kelford? If that's how u spell it..
Yep both intake n exhaust are vernier gears.
Fair call mate I understand :) oh yeah kelford cams. Another option is adaptronic ecu great value for money and an Aussie product I believe. Having a good ecu is the icing on the cake man just seems crazy as sounds like you've spent decent coin on the rest of your setup then not going for a decent computer :) sometimes not skimping out in the 1st place can be cheaper than doing it twice when ya car doesn't run how you'd expect after you outlay good dollars. I dont know what a nistune upgrade is worth these days but for a few hunge more up front the outcome will be much better.
Yeah it makes sense for sure, better have a good think about what to do, which ecu to go with, probs pop into one or two of the workshops n have a chat, see what the tuners seem to like working with n get a few tips n whatnot before crunch time on the rollers,
Can't wait to take it out for a spin tho, long time coming...
Toshi does good/cheap basic tunes. From my own experience I could've saved myself alot of time and money buy taking it to a workshop (JEM was who I eventually used). I don't want to delve into it too much but basically what Toshi told me was my issue (air leak/blocked IACV/02 Sensor/AFM) turned out to be the injector latency weren't set-up correctly. Cost me 2 retunes, and over $300 in diagnosing from Toshi himself. Rather dissappointed in my experience overall. Forked out another $1200 with JEM and have the figures to show. Smiles everytime I start her up now.
Just my 2c...
JEM, Unigroup, CRD, DVS JEZ.... Plenty of good tuners around!
Personally i use JEM but there are a LOT of good results and examples from the other guys floating around SAU :)
turned out to be the injector latency weren't set-up correctly....
But... This is the basic first step of tuning with larger injectors... Get the sucker idling and free revving nicely, then start driving, or am I missing something?
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
