On my C34 s2 stagea - Got the misfire problem sorted and it was great for a while, now this problem has cropped up.
I've noticed a definite decrease in power; it seems to rev just as hard and the boost gauge indicates boost but it's not accelerating properly. If anything it appears to boost more in the lower rev range than before; it feels like the boost comes on with less throttle but the power just isn't being delivered.
I've also noticed when accelerating slowly in second or third, as you increase pressure on the accelerator the revs increase from 1k to 2k, then drop back down to about 1.5k with no change to throttle position and I can hear a faint rumble/vibration. It takes an unusual amount of right foot to power through it then it seems to be normal.
Except for being considerably less powerful/smooth.
My first thoughts were leak somewhere or maybe AFM as I had to disconnect the AFM to change the pod filter back to the stock air box, maybe I dislodged something? Would unplugging the AFM cause the ECU to freak out a little?
https://www.sau.com.au/forums/topic/430408-strange-power-delivery/
what have you changed recently, what computer is it, and what boost are you running?
generally, the standard c34 computer is very intolerant of extra boost. You say it seems to be boosting more in the low range then stopping, that is typical of the car getting more air than it likes and moving to the rich/retard part of the maps which makes it quickly loose power.
unplugging the AFM should not cause an issue, unless you were very unlucky and something broke while you were doing it.
If you changed the intake I'd suspect a boost leak somewhere. Double check everything including all the clamp being tight. Also it can be hard/impossible to see if the intake is on the AFM properly so you may need to do it by feel.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
