Jpowys Posted June 8, 2004 Share Posted June 8, 2004 Hi Guys, I'm worried my stock boost valve is boosting too low on my 33. It is completely stock besides 3 inch cat back and a pod filter. Watching the stock boost gauge, it only seems to boost to the middle +ve mark (i would assume 3.5 psi) up to 4500 revs and then to about half way up towards the 7 on the gauge (5.5psi perhaps?). This is probably a bit unclear and difficult to explain, but it looks like it is only boosting to 5.5 psi max. Do you guys think this is a fault in the gauge, or the stock boost valve? Or is this normal? Any help would be extremely appreciated, i don't know whether to be worried or not... Thanks in advance Link to comment https://www.sau.com.au/forums/topic/43041-help-stock-boost-valve-boosting-too-low/ Share on other sites More sharing options...
paulr33 Posted June 8, 2004 Share Posted June 8, 2004 its normal operation. see below if you want to change it. stock boost on the r33 is 5psi until 4500rpm then its 7psi http://www.skylinesaustralia.com/forums/sh...ead.php?t=42895 Link to comment https://www.sau.com.au/forums/topic/43041-help-stock-boost-valve-boosting-too-low/#findComment-878668 Share on other sites More sharing options...
johnbgoh Posted June 8, 2004 Share Posted June 8, 2004 Hi Jeremy, I can think of three things 1. Yes your boost gauge could be faulty 2. The wastegate spring tension could be worn hence unable to get to the max 7 psi. 3. The turbo could be worn. Maybe the impellars/blades are worn. My 2c worth Link to comment https://www.sau.com.au/forums/topic/43041-help-stock-boost-valve-boosting-too-low/#findComment-878669 Share on other sites More sharing options...
rs73 Posted June 8, 2004 Share Posted June 8, 2004 If you're talking about halfway between 0 and +7 on the stock boost gauge, then it is perfectly normal. The scale on stock boost gauge is NOT in psi but in x100mm Hg (mercury) (1 Bar = 750 mm Hg) Therefore +7 (maximum value) = 7x100 = 700mm Hg = +/-0.9 Bar = +/- 14 psi. Stock R33 should boost to a little below the middle mark between 0 & +7 (around 5 psi) up to 4500rpm then around the middle mark (7psi) above that - as said by paulr33. Link to comment https://www.sau.com.au/forums/topic/43041-help-stock-boost-valve-boosting-too-low/#findComment-879170 Share on other sites More sharing options...
The Mafia Posted June 9, 2004 Share Posted June 9, 2004 I was just about to say that all the way to +7 = 14psi halfway = 7psi But that guage is shit, get an aftermarket one Link to comment https://www.sau.com.au/forums/topic/43041-help-stock-boost-valve-boosting-too-low/#findComment-880805 Share on other sites More sharing options...
Jpowys Posted June 10, 2004 Author Share Posted June 10, 2004 Thanks Guys, I appreciate it heaps! I won't worry any more then. And Yep, i'll be doing that mod to make it boost to 7-8 all the time rather than just 4500revs plus. Jeremy Link to comment https://www.sau.com.au/forums/topic/43041-help-stock-boost-valve-boosting-too-low/#findComment-881533 Share on other sites More sharing options...
paulr33 Posted June 10, 2004 Share Posted June 10, 2004 enjoy Link to comment https://www.sau.com.au/forums/topic/43041-help-stock-boost-valve-boosting-too-low/#findComment-881759 Share on other sites More sharing options...
