hi all,
i got a new turbo put in (or so i thought) and fuel pump, injectors, afm and ecu + tune
a few days after a clamp blew off on my intercooler piping (where the old bov used to be) and my spark plugs ended up burning out. i called mechanic and he told me to change the spark plugs (which i did and it worked) i noticed my idle sitting a bit high. i went to reconnect my boost gauge and boost controller since they blew off as well and noticed the mechanic (i ordered the turbo through him as well) had left the stock turbo on :/. been meaning to call him and ask him wtf is going on since i don't want to be jipped out of a garrett and now it's starting to cause engine knock.
does anyone have any good advice on how i could go about this situation? i got it on the invoice that i had paid for a garrett and i can't tell what would be causing the knocking and if it could be related to anything he's done? any help much appreciated thanks
https://www.sau.com.au/forums/topic/430411-wrong-turbo-and-knocking/
Knocking is thanks to a shit tune. If it looks like a stocker its not a garrett unless he fitted a high flow if thats what you asked for. This guy sounds dodgey and I'd be going back there maybe with a mate or two and dont ask. You tell. You ask and they will put it over you. You go in there say mate got some problems first things first this is a stock turbo I payed you for an aftermarket and a tune and what you gave me was stock and the engine is pinging.
But things is if you asked for a garrett turbo did you pay for a new dump? Garretts have a different bolt pattern. What you can do is pull the intake pipe and look into the turbo. You should be able to tell if its stock or a highflow. if you so happen to have an r33 feel the comp wheel and it should feel like plastic if its a stocker.
it's a small turbo with nissan on it, i ordered a gtx3071 and i compared it to the size of my friends gt3076 and it's half the size. the stock turbo was hitting 18 psi my phone cameras broken i got one photo i'll try get some more when my friend comes over
http://i.imgur.com/6M8a4vk.jpg
i asked him for a garrett and he recommended the gtx3071 so i said i'll go with that, on the receipt he put stealth garrett gtx3071 kit.
he couldn't get any further than 330hp and this is the list of parts i had gotten
gtx3071
sard 740cc injectors
power fc
3" dump pipe
300zx afm
i can tell the afm and power fc is in and my friend told me that the spooling sound will be caused by the dump pipe
also do you guys think it's safe to drive to him? it'll be about an hour drive in peak hour tomorrow or should i get it towed. i really can't afford to have heaps more problems
power fc shows the knock go up, it feels as if a piston is missing and the driving isnt that smooth (didnt boost at all when it started to happen and continued to happen) but what do i know i'm not that good with cars :(
is there anything he can say back to me to try weasel his way out of it? just so i'm prepared for excuses if it happens thanks
Yeah but thats no gtx. Again though the receipt says stealth gtx. I think what you might have is a high flowed turbo with 3071 core. It can be done but the housing is small and 250rwkw is on par with a highflow. Yes its very likely a 3071 highflow which he could say is what he gave you when he says stealth. You must say to him that no matter what he says a gtx3071 jammed into a 21u housing is not a true gtx3071 which is what you asked for.
How much knock are you reading on the power fc?
Well u can say garrett turbos dont have nissan on them for a start!
just because a part may have NISSAN cast or stamped into it doesnt mean that its made by NISSAN
Edited by StevenCJR31
so basically because the housing is a lot smaller it wrecks all the potential of it?
it knocks up and down by a few bars
Good luck with it. On aftermarket mods you will struggle with a warranty of any sort
What do you mean? This isnt a warranty issue. He got shafted. He did not get the parts he wanted or expected.
How much knock as a number? It should show you the reading as a digita bar display and as a peak number. I dont think its a great idea shoving a 3071 core into a 21u. Its like putting a lion on a leash.
i havn't really played around with the power fc i'm pretty scared of changing any settings, it looks like it was going up to 4 bars on the digital display and i could feel it when driving, too scared to start the engine now don't want to wreck any more will get it towed to him tomorrow morning and hopefully it goes well, he told me the engine will look stock but he said nothing about changing the gtx3071 and putting it inside the stock turbo i thought he meant he was going low mount so if i did get pulled over a quick glance at the engine bay won't be able to see the turbo
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
