Hi Guys,
Had my car which is a R32 GTR for nearly two years and got a haltech ecu installed last week. Drove it home from the shop and seemed ok but have just got back from a drive today and there seems to be a flat spot or miss. When I get up it the car goes fine no miss nothing. But when im just cruising there seems to be a flat spot around the 2000 rpm mark. Spits and farts a bit until the revs pick up. Just curious if it has something to do with the tuning? Never done that with the stock ecu but is now. Should I call up the mechanic who installed and tune it and be asking him to rectify it? Just thought id get your opinions before giving him a call.
Cheers
Ryan
https://www.sau.com.au/forums/topic/430424-flat-spot/
Did he take it for a road tune after the dyno run? Usually these light load issues only pop up on the street.
These things happen, as long as he fixes it free as you have already paid him for a tune... If you have issues still, it may mean he simply can't tune. (block or copy/paste tuner)
https://www.sau.com.au/forums/topic/430424-flat-spot/#findComment-6975037
Im really not sure Scotty if he did or not. He had the car over a week and also put a heavy duty clutch in. So for the cash i spent there I sort of expect it to be perfect. I'll see what he says tomorrow. I wont be paying any more to fix it as it never done that with the stock ecu. If he has an issue fixing it or refuses to I'll be happy to share.
https://www.sau.com.au/forums/topic/430424-flat-spot/#findComment-6975074
Mmm yeah when you dyno tune you just can't get to the really light loads. Its not the tuners fault as alot of tuners believe the dyno is the be all end all. My car was tuned in dyno for a good 4hrs. On very very light throttle the car does cannot gain rpm. The mix is too lean it just coughs and splutters. Abit of throttle enrichment should do the trick. What id do is tell the tuner to grab his laptop and jump in the car while you drive and have him adjust the cells and throttle enrichment. Shouldn't take long at all with a savvy tuner.
https://www.sau.com.au/forums/topic/430424-flat-spot/#findComment-6975417
  • 3 weeks later...
Can any of you guys recommend me a tuner in brisbane please.. I've been back to the mechanic and car still runs like crud. He did get in with the laptop and played around but not much changed. Find it hard to understand how they can hand back a car running like that after spending close to $5000 in their shop. I wont be going back there. I've talked to Mercury Motorsports and am thinking about taking it there for a re-tune. Just curious on other tuners out there you guys can recommend who have good previous track records.
Cheers
https://www.sau.com.au/forums/topic/430424-flat-spot/#findComment-7010334
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
