hi guys. looking at selling my r32. buying a house so i might need some extra cash. Dont want to sell the car but i might need the money to pay stupid LMI.
not been defected during my ownership and previous ownership. (bought off a mates gf)
now for the car. $7500 ono
1992 r32 gtst 5spd manual turbo Jan 2014 rego
return flow fmic (cooler cant be seen but black piping can be seen on left side.
yellow jacket coilpacks
walbro 500 pump
r34 std bov plumbed back in.
std intake with air box and snorkel
r34 gtt turbo (off 130k auto running std boost) running 12psi
3inch exh with high flow cat, std dump.
tein hr's all around
excedy hd (10000km old)
nolathane castor rod bushes
new clutch master, slave and gktech braided line
18x9 +38 all around with 235/40 595 ss.
adjustable front upper control arms( not fitted atm)
pair of bucket seats ( not fitted atm)
new front tie rods(not fitted)
hicas lock bar with jjr hose kit (not fitted)
had a small rear ender. refer pic. few little scuffs and dings so not a perfect body. factory paint is still good. could use a good clay and polish though.
probably little bits and pieces i have missed. parts not fitted will be included with the sale depending on purchase price. otherwise i will keep it when i buy another one(not my first skyline :D )
prefer sms, unless you're coming to pick it up.
0 4 1 4 4 8 5 5 1 4
located in macquarie fields
https://www.sau.com.au/forums/topic/430431-92-r32-gtst/
  • 3 weeks later...
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
