Im looking at getting some swaybars for the 32gtst. it is becoming a track car, not a drifter, so i want to buy the right ones.
Selby looks good as i can order what i want.
However i dont know what to order.
Obviously blade adjustable, but what sizes front and rear for a good balance?
I know this subject has been covered (yes i searched a lot), but its basic info, for street use, and whiteline are different to selby.
I dont know if theres anything else relevant. Silvers neomax suspension, solid cradle bushes(thats another question, change? what to?), hicas gone, adjustable this and that.
Thanks.
https://www.sau.com.au/forums/topic/430436-r32-gtst-swaybars/
It's not hard. For really stiff result, put 27 adjustable on the front, 24 adjustable on the rear. You'll probably end up with the front one adjusted away from full stiff and the rear one at max stiffness. For less of a max stifness effort, 24 adjustable front and rear, with the rear probably set to the softer end and the front at the stiffer end. Although those recommendations will really be affected by the relative spring rates.
Realistically, unless you are a race team with budget, you cannot make this "correct" with just one setup anyway. Some will argue that the right way to set up suspension for the circuit is to use the lightest bars you can. The bars are just used for tuning the handling balance. The overall roll resistance is obtained by selecting stiff arse springs. But even then that's a hassle, because bumpy tracks and smooth tracks require different compromises between spring and ani-roll bars (note there's no such thing as a swaybar on a car that's not towing a trailer). And driver preference has a lot to do with it too. You may have two cars in the same team (so the same technical backup on both, with the same engineer) and the two drivers might end up with opposite spring/bar setups and still set similar times. Make them swap cars and they will both go slower.
Yes ill always be a noob racer, but im getting enjoyment from messing with my car. you know what i mean. ;)
So 27 f 24 r is a good all round starting point
Ok, basically in general front stiffer than rear
Right?
  On 19/08/2013 at 11:50 AM, Duncan said:
haha good point....the quality has never quite been the same since they started manufacturing offshore :(
from memory Roy had some trouble with whiteline bars on this 32
correct, he went to Cuscos.
Nope, and sometimes onshore they would measure from the wrong side of the bar bwahahaha
Yuh, my experience mirrors the above. Front and rear 24mm bars just fell onto my R32. Only hassle with the rear one was it would have helped me to get the car further off the ground before starting work! Granted, I had to put the chassis mount bushes for the front bar onto the wire wheel to remove enough material to make them fit into the D brackets, but I don't take that sort of obstacle seriously.
Sorry to hijack thread but also interested in getting some sway bars down the track..
No drifting.. :)
Question is, how can I identify what sway bars are already ON the car? They look stock to me and can't find any markings.
Edit: Maybe get some vernier calliper's and measure how thick they are?
Edited by Zrobe
You can just measure the thickness, but that might not tell the whole story. The stock front bars on R32s are hollow, hence they are much lighter than a similar sized solid and also somewhat less stiff than a similar sized solid. It is not possible to know exactly how thick the walls are on these hollow bars though, so it's not possible to calculate hoe stiff they are relative to a different sized aftermarket bar. If you have or can make a rig to test how stiff they are then you can compare them. Making such a rig is not super difficult, it's just a lot more work than most people are willing to put into it.
FWIW, my (originally) auto R32 (also a 1993) had a 16mm solid rear and a 22mm hollow front.
Okay, no worries thanks heaps.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
