This 'jet pump' is only ever used/enabled if and when you put Jet Fuel (Jet A-1) in your Skyline...
There is a reason why the taillights look like afterburners you know ;)
Nah in all seriousness I would like to know too!
  • Like 1
If the jet pump in a Skyline is anything like the jet pump in a WRX fuel tank, then it is used as a venturi effect pump to transfer fuel from the other side of the hump in the bottom of the fuel tank. It works by using the return line pressure to create a lower pressure in the suction pipe, this draws the fuel out of the otherside of the tank and deposits into the side where the fuel pump pick up is. These units are used for a number of reasons in that they are cheap, self priming, very low maintenance and also very cheap. The problems that can occur with them are when you use larger injectors and greater IDC's, there may not be enough pressure and volume in the return line to the tank to drive the pump.
If you imagine that the compressed air is the return line and the vacuum is the line from the other side of the tank, then this give a visual idea of what is happening.
If you only have a lift pump on one side of the tank (due to the that being siting over the propshaft, there is a hump in the bottom of it) and the jet pump is not working, then you have to rely on the movement of the car to transfer fuel from one side of the tank to the other, so if you are going around a corner and this causes the fuel to move to the other side of the tank to where the lift pump is then it is possible to either not be able to get the full amount of fuel out of the tank, and dependent on the size of your surge tank, the pumps used and the engines fuel consumption, then it could also be drained.
Outlined in Red, is this the jet pump?
Is it supposed to have a hose attached?
(if so, all I had in my tank was what's in the pic.)
If that is the in tank side, then no, they usually just spray into the tank from the nozzle to remove any possibility of flow restriction, the two moldings into it are the return from the fuel rail (center) and lift pipe (outside edge)
So if I have a lift pump, surge tank and external pump. I shouldn't need it, should I?
Because the external pump performs a similar function.
Correct. Just ditch it.
The Stagea's run these vac generators to suck the fuel over from the other side of the tank too. I didn't think it would be required in a 33 as they run a single tank behind the back seat don't they?
So these can just be ditched? It won't create problems with fuel getting stuck on one side of the tank? I also need to replace the moulded fittings with AN fittings, but I drive around pretty sedately on the streets, so I don't think I'd be doing much cornering hard enough to swish the fuel around...
Ah, just re-read Scotty's post.
So in an R34 with just a single internal fuel pump, I can't ditch this jet pump? What are my options for using AN fittings in place of the moulded ones?
This is my plan:
I think I made a few slight changes since making the jpg, but that's the crux of it.
I plan on making a full DIY write up. From what I can tell there isn't one out there (hence threads like this)
I understand the majority of the plan, but still not quite sure what you are doing with the fuel lid. Are you just using the one AN bulkhead fitting and keeping the plastic return fitting? This is what I think I am gonna have to do, though I'd prefer not to...
I have also thought about using a Speedflow tube adapter to convert the plastic fitting to an AN fitting. This would maintain the jet pump setup, AND allow me to run PTFE hose. The only thing is, the plastic fitting is an odd design and might not work with the tube adapter.
The 040 and 044 pumps are not E compatible according to Bosch, having said that, there are a large number of cars that run them (mine included) that do not seem to have an issue.
A solution to this could be two separate lift pumps (such as these http://www.efihardware.com/products/261/lift-pump-340hp-Rollercell) drawing from each side of the tank using the pickup for the lift pump as well as the standard pickup.
I'm sure they say that because E85 kills a lot of pumps due to the crud it stirs up.
Pump comes back. Pump comes back. Pump comes back. Then the quality manager for Bosch goes "put on the package we don't warrant returns for E86 anymore".
This is overkill for a lift pump to a surge tank. But it's probably the best in tank pump for E85:
http://www.sonicperformance.com.au/F90000267/Walbro-Fuel-pump-Intank-E85-450lph/pd.php
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
