evening all,
Right, i am after a bit of advice with regards to this problem.
I have a daily that i drive everyday into work. and the V35 is kept as a weekender / fun car and is lucky to get driven 60km's a month. the car was last serviced back on the 29th January, and here we are in freaking august already, the car has only done 1,200km's since the service. is it any harm in leaving it for another month or two? i now the lubrication of the oil and the contamination occurs, but if its done so few kilometers since the service is this still a factor?
reason i'm trying to leave it ( or simply not drive it), is because i'm heading overseas next month and money is currently tight at the moment. after i come back ofcourse its going to be the first thing on the list to do.
currently using synx3000 with a veruspeed/nismo oil filter
Edited by liger
https://www.sau.com.au/forums/topic/430464-6-months-without-a-service/
I often work overseas for 5 months at a time. Essentially, I don't bother with servicing my vehicles before I leave. I save it for after I get back, provided I haven't exceeded the required kms before service. Otherwise, if I expect to continue to drive the vehicle for anything less than 500km, I just treat the engine nicely rather than accelerate its balls off as I usually do and then worry about the servicing after the long absence.
It resulted in a well looked after engine in the old Max Sr and it certainly hasn't upset Max Jr in any way. That said, I still get paranoid after the long absences and squirt a bit of oil down the spark plug chambers before kicking the engine over after the change of fluids, just for that extra little bit of love. Many say its overkill, I just call it love. :)
I've left my 200 longer than that - a few months ago I was using it maybe once or twice a month and probably went for a full 12 months, did about 1500km in that time period. No harm done, oil was fairly clean when it came out
And I'm pretty anal about the servicing on all our cars
It should be fine. U actually don't need a service at all til the KMs are due.. You should follow the KMs and not the months.. If you don't drive, your oil should remain new. There is no difference to parking your car there and keeping the oil in a bottle on the shelf.
Until u actually drive the car and use the oils life I would see no point in servicing and changing oil.
E.g. I service my car today and go overseas for 6 months.. When i get back does that mean I must service my car? Even though I haven't driven it?
P.s. I'm a mechanic and this is what we, my work and I have always told the customers. Unless its a new car and has new car warranty, then u must stick to the logbooks to avoid warranty being voided..
    • I guess when I say it's a POS I mean.. the solution and the stuff has the capacity for maybe... 1 spot. You know, as a spot cleaner. What I really *want* is the ability to do an entire car, all upholstery, all carpet, mats, all seats, door card inserts, A pillars, roof liners, etc. In one go. I get lured by all the jank that comes out and think "I'd like to be able to clean to that degree"
    • I've got one (not the car one, the domestic spot cleaner one, which is basically the same jobbie) and have driven it hard for hours and hours at a time. Grimy sofas, 6' floor rugs, etc. I'd blame your specific example rather than the whole category. I haven't used mine in the car, because.... you know, it's my car. So there is no-one else's ball sweat in the driver's seat, there's no kid food/drink spills or hand prints inside because they've never had an opportunity to put them there. You know, basic, standard Skyline rules.
    • I normally run with I think a 10mm, and definitely use the second handle you can add to a drill. They hurt when they bins up!   For the crush tube, once all subframe is clear, I'd try some stilsons and see if I can get it to start to twist.
    • Probably because they couldn't, because the use of the variable resistor to create a "signal" in the ECU is managed by the ECU's circuitry. The only way that VDO could do it would be if they made a "smart" sensor that directly created the 0-5V signal itself. And that takes us back to the beginning. Well, in that case, you could do the crude digital (ie, binary, on or off) input that I mentioned before, to at least put a marker on the trace. If you pressed the button only at a series of known integer temperatures, say every 2°C from the start of your range of interest up to whatever you can manage, and you know what temperature the first press was at, then you'd have the voltage marked for all of those temperatures. And you can have more than one shot at it too. You can set the car up to get the oil hot (bypass oil coolers, mask off the air flow to oil coolers, and/or the radiator, to get the whole engine a bit hotter, then give it a bit of curry to get some measurements up near the top of the range.   On the subject of the formula for the data you provided, I did something different to Matt's approach, and got a slightly different linear formula, being Temp = -22.45*V + 118.32. Just a curve fit from Excel using all the points, instead of just throwing it through 2 points. A little more accurate, but not drastically different. Rsquared is only 0.9955 though, which is good but not great. If you could use higher order polynomials in the thingo, then a quadratic fit gives an excellent Rsquared of 0.9994. Temp = 2.1059*V^2 - 34.13*V + 133.27. The funny thing is, though, that I'd probably trust the linear fit more for extrapolation beyond the provided data. The quadratic might get a bit squirrely. Hang on, I'll use the formulae to extend the plots.... It's really big so you can see all the lines. I might have to say that I think I really still prefer the quadratic fit. It looks like the linear fit overstates the temperature in the middle of the input range, and would pretty solidly understate what the likely shape of the real curve would say at both ends.
    • I got a hand held bisssel one and it's a piece of shit. Doesn't work for more than about 5 seconds. So much so that I nearly refuse to believe any wet dry vac actually works or has enough suction to clean the carpet of a car. I'm discouraged as all the good ones are $300+ for an unknown result. I saw MCM did a Ryobi video where they use this thing: https://www.ryobi.com.au/products/stick-vacuum-cleaners/18v-one-hptm-brushless-spot-cleaner-tool-only Anyone have any experience actually using a tool like this when not paid to showcase it?
