So this morning I went to drive to work and my car just gave up. I unplug the igniter and the air flow meter when ever I go away for a weekend.
So I plugged them back in and then started the car. It idled for a little bit and as soon as I put it in gear and went to take off it stalled.
Now it won't even turn over.
Any ideas?
I checked both the igniter and the airflow meter plugs. It's my daily so I'm pretty screwed without it
https://www.sau.com.au/forums/topic/430484-car-wont-start/
Left your lights on? :P
I had a bit of a scare this morning. My electric key wouldn't unlock the door so I had to do it the old fashion way which released the alarm. Had no idea how to turn it off without the key working but then it just worked :D Small scares.
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975765
Could still be a flat battery braaaaaaa. If it literally doesn't turn over at all, then either your starter motor is f**ked, the battery is dead, or a fuse/solenoid has shit itself somewhere. It's almost certainly nothing to do with the ignitor or AFM, unless it DOES turn over but just doesn't fire.
When you put the key in the ignition and turn it to start the car, describe EXACTLY EVERYTHING that happens - does it make a rattle/clicking sound? Does the engine turn over but not fire? Does it prime the fuel system?
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975779
No good man. Let's hope it's nothig major ! Summon Rob # He always seems to give great guidance / food for thought.
edit: I also had this similar issue couple of weeks ago. NRMA came out for 30 seconds to plug my alarm plug back on the battery hahaha I felt like an idiot.
Edited by RosieR34
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975780
Nah it has power you can hear it trying to turn over but it just doesn't grab. Lights 100% weren't on.
are you saying you can hear the starter spinning but not turning over the motor?
if this is the case turn it off then flick it straigh back on. sometimes will cause the pinion to push out as and grab the flywheel
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975822
Okay so when I turn the key I can hear it making the normal starting rev noise trying to start the engine.
But it just doesn't grab and start up. I have had a flat battery before and noticed it just makes a slight noise when that happens.
This is different. It's very similar to if you ran your car to empty and then tried to start it.
I do have a full tank of fuel though
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975846
if you're getting a clicking noise, kinda hollow, then your starter is gone (happened to my mate) if all electronics work fine then your battery is also fine...next up would be spark plugs? no reason for them to randomly die but who knows, could happen? maybe put up a sound clip of you trying to start it? if you said it sounds like trying to start a car on empty tank then yeah, might be sparkies cos that's what mine sounded like when i needed to change them too.
though one more thing - check the loom connections to the battery, all terminals are secure and not wiggling - then grab the looms and give them a wiggle, a few times, try and start the car, and wiggle again. might be a loose connection somewhere.
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975927
Stop trying to start it and take it to a shop. You will risk detonation if it starts to flood the engine.
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975933
Still didn't make it very clear lol....
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6975992
Hahaha I was in a huge rush this morning so my mind was all over the place. It's kind of hard to describe a noise. Ill check the plugs again when I get home and also pull out the spark plugs and check them.
I can hear the fuel pump prime and then stop. But I'll pull a fuel line off and check that as well.
Anything else I should be checking as well?
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976007
i don't mean to sound like a dickhead (especially towards such a little sweetie as yourself, Dan), but you're still failing to answer the damned question lol :P
The engine "turning over" has nothing to do with it firing up - when you turn the key to the start position, does the starter motor turn the crankshaft successfully? I repeat - this has nothing to do with the engine firing, simply whether or not the starter is doing its job. If the battery is flat or if the starter motor has failed, the answer you'll be giving me here is "no".
When the key is turned to the final stage in the ignition (where it is supposed to start the engine), a few things should be happening - power is given to a small solenoid on the starter motor which causes the pinion gear on the starter motor's shaft to move out and engage with the flywheel. It then also gives power to the starter motor itself, causing it to turn the flywheel. If your battery has sufficient charge, these functions will still go ahead - the engine will "turn over".
Should the engine fail to fire as it should (and subsequently begin to run), the issue at hand will lie somewhere in the ignition system or fuel system (I'm not sure what will happen if the AFM is unplugged - will it not fire at all or run in some sort of limp mode?). Given you unplugged the AFM and ignitor, this is most likely where the fault lies - potential bad connection in the plugs (possibly from moisture as you suggested), or potential failure of one of these parts (possibly just bad luck when you plugged them back in).
While there are many many many things that can stop an engine from starting correctly, you should always start the investigation with things that have recently been fiddled with, especially if the car was running fine before you fiddled with them ;)
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976035
He means it wont fire.
So, basics guys, its spark or fuel.
you mean fluid lock? bust the head off?
Haha no pre-det. You would burn out your starter motor/flat battery before nearing hydrolock.
Dan by some electrical cleaner clean ignitor/afm my as well clean tb and cas sensor at the same time will get rid of moisture Charge the battery up give her another crack.
If its still no go it has to be spark or timing since you can here the pump prime.
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976104
Hey Troy,
So I don't know the difference in the noise between those two steps in the start up you are talking about. Ill have to wait until I get home this afternoon. Might try get a video of it and send it to you.
I'll post up here this afternoon around 6:30 when I get home and start getting my hands dirty. Hopefully I can sort it out before work tomorrow
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976126
As per our sexting just now, you finally answered my question :P
Check AFM and ignitor plugs first - Do what Pat suggested and get some electrical contact cleaner to spray on the plugs and clean them out. Hopefully it's just moisture.
If that doesn't fix anything, check fuses. If the fuses look fine, then consider that by some unlucky chance either your AFM or ignitor shat itself at some stage through this adventure lol
https://www.sau.com.au/forums/topic/430484-car-wont-start/#findComment-6976187
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
