btw when you say you have to push it uphill to clutch start it, is that because your house is right at the bottom of a hill? because you can clutch start in reverse too. If you are careful (clutch and brake as soon as it fires) you can even do it in your driveway, it only takes a couple of klm/h to start a car.
ecutalk should show most of your ecu values and voltages on a PC which can help with spotting a dodgy sensor like an AFM or TPS (by voltage) or even CAS (by seeing fluctuating voltages)
Haha i use to reverse roll start my car down the driveway for two months. (not the skyline) Edited by Pattey21
Finishing work late all this week. (Forced Overtime) KARNT$$$
I'll be home by 5pm. Praps I can just come by and Help ya!
Yes Laptop. :thumbsup:
If you have the time Rob :)
Working late? lol I don't finish until about 5:30 so that works out perfectly fine.
Does your 33 have the ignitor on top of the cam cover?
Haha nah nothing in the intercooler pipe.
Drove it to and from work as well for the week.
Tried all different things Zeb such as pumping the gas, light pedal etc.
If you both have the time to come over then I would love the help.
Rob, the ECU talk would be a great help (I have never used one though)
And Zeb your wise mind would be great as well.
If I could find an ignitor then that would be perfect.
Yeah man, no Problem. Txt or PM your addy. I'll be there.
Is your car on the street? Will it be safe? Uphill to get to your carpark?
If flatish, I've seen an RX7 reversed using just the starter motor. NOT IDEAL!
But if your stuck on a train track and the train is coming, it might just get you out of trouble.
Maybe get an ignitor off brennan or surely someone on here in act must have a s1 r33. Hopefully ecu talk is fine with the daughterboard and can diagnose but if not researching correct operating voltages for all the sensors would be handy when the guys come around tomorrow or if your lucky get somone with a s1 to use as a "rough" reference.
then its just a process of elimination. good luck with it buddy
This all sounds familiar........
Im sure this happened to me once.
Just have to remember what it was.
>_<
Trying..... hang on
>_<
Itll come to me....
I think the ignitor wasnt earthed or the wiring up there was fked, coilpack harness earth, shorts etc
Also had the idle circuit do that, the ac valve or something, that thing bolted to the inlet manifold.
Another time i lost a hoseclamp on the pipes and it died as soon as boost pressure popped it off.
Hope it helps, good luck.
Edited by D.I.Y. Mik
might sound silly, just double check the CAS is plugged in and hasnt come loose.
Not sure what you've tried in the last 4 f**ken pages lol, ain't no way I cbf reading this first up on a Monday - but as above, have you checked the CAS at all? It's just as unlikely as any other part you haven't touched recently coincidentally failing, but it fits the symptoms (battery fine, car started fine, ran for a bit then died, now won't start).
I assume you've gone over fuses by now?
It's still possible that you've had a run of bad luck and damaged the wiring for one of the plugs when you unplugged it or when plugging back in. When you've got another person to help you, have them crank the engine over (*try* to start it) while you fiddle with the plugs/wires - see if anything happens while you're wriggling them around.
I agree with Richard, It sounds like either spark or fuel. Pull a fuel line off and let it prime as fuel should spill out of the line. If it does that means you are getting fuel. If you are getting fuel and you have spark do a compression test. Fuel+spark an engine should start even if it runs like shit. No compression=no start.
oh also how many times have you tried to start it? You are risking flooding the engine. If you have tried to start it quite a few times get a battery charger/new battery as that will kill the battery very quickly.
Edited by Anfanee
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
