btw when you say you have to push it uphill to clutch start it, is that because your house is right at the bottom of a hill? because you can clutch start in reverse too. If you are careful (clutch and brake as soon as it fires) you can even do it in your driveway, it only takes a couple of klm/h to start a car.
ecutalk should show most of your ecu values and voltages on a PC which can help with spotting a dodgy sensor like an AFM or TPS (by voltage) or even CAS (by seeing fluctuating voltages)
Haha i use to reverse roll start my car down the driveway for two months. (not the skyline) Edited by Pattey21
Finishing work late all this week. (Forced Overtime) KARNT$$$
I'll be home by 5pm. Praps I can just come by and Help ya!
Yes Laptop. :thumbsup:
If you have the time Rob :)
Working late? lol I don't finish until about 5:30 so that works out perfectly fine.
Does your 33 have the ignitor on top of the cam cover?
Haha nah nothing in the intercooler pipe.
Drove it to and from work as well for the week.
Tried all different things Zeb such as pumping the gas, light pedal etc.
If you both have the time to come over then I would love the help.
Rob, the ECU talk would be a great help (I have never used one though)
And Zeb your wise mind would be great as well.
If I could find an ignitor then that would be perfect.
Yeah man, no Problem. Txt or PM your addy. I'll be there.
Is your car on the street? Will it be safe? Uphill to get to your carpark?
If flatish, I've seen an RX7 reversed using just the starter motor. NOT IDEAL!
But if your stuck on a train track and the train is coming, it might just get you out of trouble.
Maybe get an ignitor off brennan or surely someone on here in act must have a s1 r33. Hopefully ecu talk is fine with the daughterboard and can diagnose but if not researching correct operating voltages for all the sensors would be handy when the guys come around tomorrow or if your lucky get somone with a s1 to use as a "rough" reference.
then its just a process of elimination. good luck with it buddy
This all sounds familiar........
Im sure this happened to me once.
Just have to remember what it was.
>_<
Trying..... hang on
>_<
Itll come to me....
I think the ignitor wasnt earthed or the wiring up there was fked, coilpack harness earth, shorts etc
Also had the idle circuit do that, the ac valve or something, that thing bolted to the inlet manifold.
Another time i lost a hoseclamp on the pipes and it died as soon as boost pressure popped it off.
Hope it helps, good luck.
Edited by D.I.Y. Mik
might sound silly, just double check the CAS is plugged in and hasnt come loose.
Not sure what you've tried in the last 4 f**ken pages lol, ain't no way I cbf reading this first up on a Monday - but as above, have you checked the CAS at all? It's just as unlikely as any other part you haven't touched recently coincidentally failing, but it fits the symptoms (battery fine, car started fine, ran for a bit then died, now won't start).
I assume you've gone over fuses by now?
It's still possible that you've had a run of bad luck and damaged the wiring for one of the plugs when you unplugged it or when plugging back in. When you've got another person to help you, have them crank the engine over (*try* to start it) while you fiddle with the plugs/wires - see if anything happens while you're wriggling them around.
I agree with Richard, It sounds like either spark or fuel. Pull a fuel line off and let it prime as fuel should spill out of the line. If it does that means you are getting fuel. If you are getting fuel and you have spark do a compression test. Fuel+spark an engine should start even if it runs like shit. No compression=no start.
oh also how many times have you tried to start it? You are risking flooding the engine. If you have tried to start it quite a few times get a battery charger/new battery as that will kill the battery very quickly.
Edited by Anfanee
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
