My bet's something to do with the ignitor. Failing that, AFM. Failing THAT....fark lol, could be anything from there since Dan hasn't fiddled with anything else prior to it dying
Maybe it's all Dan. He just doesn't know how to turn the key properly. CLOCKWISE BRO!!!
f**king noob man, noob :P
ECU talk may show if a sensor like CAS, TPS or AFM is showing abnormal readings, or no reading at all
Switching parts is a better option if you can because it rules out everything with your part (that may not always be obvious just from the sensor reading)
ECUtalk - Code 55 (all Good)
Battery voltage 10.6 V, 11.7 V with jumper leads. Jumpstart No Go.
Vapour from exhaust when Cranking.
Disconnected and reconnected the ECU.
Checked All Fuses.
Start ya Bastard sprayed into the Plenum, No Bang.
Strongly Suspect the Igniter. :( or Coil Loom (abit Crispy) but mostly igniter.
First turn of the key it fired ONCE but would not catch...
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
