Hey great news to hear it is running, and well done to the guys who were able to heap over to lend a hand....that's how car clubs should be.
However....just because it is running now doesn't mean you have no problem. As Peter Brock once noted, he never met a car that fixed itself. Whatever was wrong still is, and it will let you down again one day, maybe in a less convenient place.
I would suspect bad wiring as the most likely culprit (I think someone else said that a few pages ago).
Get the car started, and the jiggle the following wiring:
*Into the ignitor from the engine loom
* from the ignitor to each coil pack
* into the CAS.
I think it is likely that when you fiddle with one of them the car will start to misfire or even stall. When it does you know which part of the loom is the problem. Don't tug on it like a 14yo boy, but don't be to gentle either because you may not make the issue recurr.
I'm sure I could get this baby to 15!
Thanks Duncan
I am going to organise a new igniter and also a wiring loom anyways because both seem dodge.
The loom is nice and crispy from the heat and the igniter of course has that crack/hole in it.
And yes the community came together perfectly on this one. Reminds me of home and away or Ramsey St
Thanks Duncan
My top bloke detector just went off the charts lol
<3
Thanks Duncan
check out some local wreckers mate..... :woot:
never know what youll find.
Hey Daniel just so I am clear, the loom into the ignitor and into the CAS is not the same as the short loom between the ignitor and coil packs (which yes, is often crispy!).
You should check them too, we don't want to see you stuck again! (new thread, or season 2 on this one???)
Lol I would just refresh this thread Duncan ;)
Ohh true well I wonder how you go about getting those fixed.
I guess an auto electrician would do that sort of thing.
I'll have to check them out on the weekend I think.
Too many nights in a row sitting in the dark and cold
we can rename this thread to the "ACT - Car is broken" thread. anyone whos car dies posts here! sticky it! lets get it to 1000 pages!!!!!!!!!!!!!!!!!!!!!!!!! this is skylines we are talking about. in theory should only take a week.
don't worry about the compression. if you lost half of it you would notice immediately the first time you put your foot down.
shelly, did you get a flat battery? if it's the alternator you will almost certainly get a warning light on the dash. plus it's easy to check with a multimeter....you should have about 12v with the car off, and more than 13.8v when it is running
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
