Hey guys my high flowed standard housing turbo with gt30/76 internals has died, I am on the hunt for another turbo.
What would be good for 250-350rwks and good to drive on street without to much lag?
I am leaning towards a garret gtx30/76 with a 82 rear housing what are your thoughts?
My engine has had a full rebuild with forged pistons eagle conrods etc etc. the engine build cost me about 11k so im hoping remac done a good job haha, so far so good.
Any links to turbos would be appreciated.
https://www.sau.com.au/forums/topic/430525-need-a-new-turbo-what-do-i-buy/
  • Replies 87
I heard those hyper gear turbo figures are no where near what people can get here in sa workshops, and that they won't last as long as a garret or hks turbos.
As for fuel system boostworx threw in a some deatschwerks 550lph fuel pump.
SA workshops must have pretty shit tuners then. :P
They will last longer than a Garrett if high volume clean oil is supplied to them. Ball bearings are much more susceptible to oil quality issues and don't like massive thrust loads, especially when shoved into highflows, as I guess you have already found. A bush highflow can be rebuilt for $200 odd anyway.
Boostworks didn't throw in a 550Lph pump, there is no such Deatschwerks. The e85 400lph isn't available yet so I guess it's the DW200 or DW300?
Personally I wouldn't choose a GTX wheeled turbo.
GT3076 is fine but possibly a small framed Hypergear with roller bearings to get the better transient response would be a winner.
IMO 270rwkw ish on pump fuel for a Stagea is plenty without too much penalty down low.
Is power referring to in all wheel kws or rear only? Any way the difference in AWKW and RWKW is 13% (RWKW is obviously higher).
The Stagea tows a much heavier chassis and with 4WD the engine takes much more load compare to a standard Skyline, which creates a similar effect as if the dyno ramp is much heavier. Means exhaust side is hotter and turbo spools up quicker.
So a larger turbine end compare to the .63 is preferred, and our Billet SS2 in .82 would be some thing nice for this application. if you are serious about power and response then get a high mount manifold + EX gate, and run the SS2 Alpha version, which has ceramic roller bearings with VNT turbine. I haven't seen any thing that is more responsive in the same HP range.
Still being an auto I'd prob head towards a 3071 for response , but I'd definitely look at hyper gears turbos they seem to be the goods . My 3076r is a good thing but I'm running a small .63 exhaust housing with an external gate , so when it comes on its like a sledge hammer
doesn't matter..if you use jaustech dyno, no turbo will get near what people quote anywhere else, it seems to be a heartbreaker
you'll struggle to get 250-26rwkww on it..don't worry about 350..lol.\
I have a hypergears G3 type A , on that dyno on 98 it did 258rwkw i think with boost 19 to 16ish up top. Jaustec apparently did 5 other 3076 56T .82 setups
and they all made in the 250's maxed apparently on 98..However i found my blow off valve leaking after that, so i think theres a bit more in it as when it stopped leaking ...19psi it was setup to went to 25-26psi...
Anyway i get 2-3psi on stock converter
2-3psi by 2300rpm, it pulls nice from 2800ish.(theres a lull around 2500..thats not the turbo, thats the turbo trying to build boost against the stock converter and the converter holding it back ).after that i have never checked as i have a digital gauge but from there to 3800 i get plenty of boost,
enough to out acceralate normal traffic, easily and climb big hills etc without downshifting
3800rpm i get 20psi, and it makes goes fastest if i shift at 7300rpm and holds okay to 7500rpm then drops off.
the FNT is good, from 2300- to 3800 it flat out works
I'd go the ss2 if i had the choice again, having said that ,what i have i really enjoy and wife likes it to
Unless you piss of the 98 octane , you'll never make huge power, 250-270rwkw will be about it, dyno depending without retard lag
Really, your wasting that pretty motor unless you go E85/WMI/ or fuel spike
cheers
darren
Edited by jet_r31
Im on 3 weeks holidays soon, going to Melbourne for a few days.
Might just come home with a hypergear Billet SS2 in .82, wish the stageas turbo wasn't routed otherwise i could have drove it over and got hypergear to fit and tune it for me.
Why you would consider anything but a Hypergear is beyond me TBH. Stao has achieved some fantastic results and there is nothing in the same league dollar for dollar. And the support available, from Stao and others who have fitted HG turbos, is second to none and very evident in the HG turbos thread.
I was all set to shoot for 300awkw using an ATR43G3 until some bastard stole my motorbike :( My tax return had to go to replacing it instead.
SS2 is a better turbo compare to the G3. it eliminated the internal gate boost dropping issue through compressor blade profile. So when used as stock replacement it makes better power and response.
I only build turbocharger, I don't work on cars (apart from my own). but I can organize a good mechanic that I work with to have the new turbocharger installed.
Yeh i have external..on dyno before fixing leak, it went 19-16psi..it now holds 19-20 psi on wastegate spring tension so i have no idea what power it makes atm
so this summer will take it back, touch up tune and see if it makes power with a tad more boost(22-23psi)
to cold to work on cars atm..lol
cheers
darren
Edited by jet_r31
Hypergear do you have hypergear Billet SS2 in .82 in stock?
I will be in melbourne on the 8th of september till around the 12th i think, will be popping in to see you on one of them days.
We can have a chat to see whats best for my stag.
cheers
darren
"Ha ha "more like to hung over from last night to work on cars today
Yes I can have one built and ready for pickup.
