  • Replies 87
My mechanic and i have spoke about turbo choice, we are going ahead with the garret gtx3076r.
Thanks for your help hypergear and thanks to any one from the skyline australia forum for helping out also.
Hmmmm just don't know ! Nothing wrong with that choice, i run it! but a hyper gear would be awsome combo on your car, what rear housing you going to run? you going internal or external gate?
Well I believe there is a strong Bias on his engine builder as many older timers did grew up with the company, even thou I do not agree that it is a better choice for factory manifold and internal gate, but I respect their decisions.
As developments continues, I will make sure the SS internally gated series are always a better bolton option for the Nissan Rb25det engines.
I run the same turbo, the GTX is only a good choice for someone planning on running 25+ psi, otherwise the GT or a Hypergear is a better option imo.
It is a fairly laggy 400kw on e85 turbo choice. What do you want out of your setup?
Just saw he wants to run x frame mine is gt 3076r not to laggy at all with a .63 external and manual lol makes good power, but will expect it to nose over soon on the next time hopefully get 350+ out of it b4 it does , but there are much better choices out there now, more response, better flow, I know I will be changing to some thing else one day soon, but just like to see where I can push this combo too first .
2000 rs you have spent massive $$$ on that stag now and deserve to make good power so be very very careful on turbo choice and who you take advice from . There are ppl on here who are specifically in tune with stagea's and rb engines and turbo choice too suit . You've also got too look at what power delivery you want , do you want a dyno queen lag monster or something that will actually get the stag up and moving street style, do you want a linier v8 style power delivery or do you want a head snap . Be careful on what path you choose
And mechanic so strongly in favour of one turbo over another (when the one he's against is arguably the best choice) isn't a mechanic worth taking your car to.
Seriously, for what you want I doubt you'll find a better turbo than a HG. There are lots of results out there which demonstrate how perfect HGs are for RBs. If your mechanic isn't confident using one, then he has a problem, not the turbo.
I vote find a new mechanic
4bidn1 has a a 3076 56t ,63 same setup/gate on stockyband he had auto aswell
i have hypergear g3with old bigger 58t comp wheel/bigger turbine/bigger .82 exhaust housing
now lets guess which one has way more power under 3800rpm
the 3076 woudnt even make 1psi on a stock converter..
of course you workshop woudnt know this...
remember you have to move a big heavy car. Good ole adelaide
workshops..lol
.82
internal wastegate.
Dont want the cops to have a heart attack when they pop the bonnet.........
Edited by 2000 RS
I am running forged pistons, plan on getting mv auto to strengthen my trans and put a stall converter in..........
The workshop im sending my car too works mostly with rb engines, they have drift cars also.
They have worked with alot of HG turbos, they say they cant get no where near the figures HG have posted on the net Plus the front housing on HG turbos are to big for my application as i am not running a top mounted turbo.
What figures do they get on their Garrett range?
Just on that, are you buying the turbo from them?
With the gt3076 they make around 330rwk on a manual.
And yes they are getting the turbo in for me, i payed a deposit today. the gtx3076r is $2450
The gt3076 is $2050
You pay for what you get these days i guess.
well not really..you got assf**ked by bill with your first turbo, assf**ked by your engine builder
theres plenty of info here to tell you why the gtx3076 woudn't be a good thing for what you want
but you seem to like to get spoon fed,your the type of customer workshops dream about..lol
money doesn't buy brains sadly
Edited by jet_r31
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
