  • Replies 42
Have you checked the chassis number with Nissan to vertify that its in its original colour? That blue doesnt look standard to me and why the hell would you paint R34 GTR wheels white?
If it checks out then there is no reason not to buy if you are satisfied in your purchase.
Roy, Not a v-spec .. but it still has brembo's - lets hope the sale goes through :(
Blitz: good spotting.. it is a lighter than usual blue colour (I think!)
Though I am told by the dealer its 'Nismo Blue' - the car has white nismo gauges + dials, nismo pedals, plus a small, legit looking nismo badge on the opposite side to the GTR badge. The dealer told me he wasnt sure if it came out of the factory as a 'nismo' or if it was just a basic cosmetic mod the original owner did.
Has anyone heard of a nismo spec r34 gtr?
Also, the interior trim looks exactly the same as the interior in a GTR v-spec.. I dont remember the standard trim but is a standard GTR interior seats/trim any different?
Basically all the knowledge I really have of the vehicle is that it arrived in Australia with close to no kilometres in 1999 and has been driven and babied here ever since, and has done about 50,000kms since then on the digital odometer.
For the record, the car drives absolutely perfectly, its in as new condition and is a bargain I couldn't go past.
How much was this " bargain for " ? :wassup:
I am pretty sure i have seen this one years ago - the white 6 spokes ring a bell - I sat in it back in 2000. Was it complied by skyline imports? If it was it would have been probably one of the first 34 GTR's to be complied in Australia....
My bet is that it's been in a huge accident...
Something about the car just doesn't sit right. From the paint, to the wheels, to the dealer spinning stories about a "Nismo" model to explain the different blue colour... Just seems verrrrrrrrry dodgy.
Give us the engine number and chassis number and I'll try and get John @ UAS to look up the details of the car for you.
Pentae - What was the go with this car in the end? Did you purchase or was there issues?
Yeah I got it checked out, it was fine. - it had some previous panel damage on the left side of the car that had been repaired professionally and was unnoticeable without looking under the car.
The only thing wrong with the car was it was resprayed in a non original colour.
Did you get the RACQ report on this car because i rang them up last week about it and they told me it had been checked out by RACQ and every thing was fine they could not fault it ,and i specifically ask them about any damage or if it has been resprayed and they told me no it was nismo blue and it was some rare colour,
never heard of it on an R34 GTR also so noticed the GTR and nissan badges on the boot are in the wrong spot the GTR badge is about 20mm to low and the nissan badge is about 20mm to high this is why i thought it had been in a accident that and the nismo blue but they still insisted it was normal.
They also advertised this car in another car site as a V-spec for $65,000 with different number plates a bit suss.
No I didnt get an RACQ report on the car, I took it to one of the most reputable workshops in brisbane for imports and gtrs. :)
The car has definately had a respray from white; its not nismo blue.
And yes it was complianced through skyline imports.. my mechanic knew the guy who imported in about 4 of them and sprayed them all in this sky blue colour.
The vspec your talking about could be a different car..
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
