Planning my shed and have a few questions from those who have done it before.
Here's what I'm planning. I will be building it myself/with mates.
7x10.5x2.7m WxLxH (11 degree roof if that matters).
Gable end will have 2x 2.5x2.7m WxH roller doors. Current quote has motors on those but I think I might save the $500 and take them out.
There's 1 personal access door on the quote also.
That comes as a kit delivered for just under $5500 through Best Sheds (with the roller door motors taken out and $700 delivery to me but the price is substantially better than anything else I have seen so far).
My questions.
- Is this a decent price? I'm in Victoria if that matters.
- What's the consensus on Windows? I thought about adding one up the non roller door end, this adds about $200 to the price.
- What have people done insulation wise? I want it to be semi comfortable and am willing to put some basic insulation in the walls and under the roof sheet, assuming foil then batts? I will use the same kit on the doors I used on the house garage doors which worked well, it was a GDI
Reflecta kit, two bits of aluminium with honeycomb material sandwiched between. I will put in at least 1 whirlybird and have a plate to block it during winter.
- I'd like to paint the floor, easier to paint the slab before the shed goes up? Or can it not sit out in the weather?
Appreciate any comments/feedback.
Cheers
https://www.sau.com.au/forums/topic/430542-shed-prices-and-questions/
RE: painting the slab, you will most probably scratch the buggery out of the paint in the process of erecting the shed. I painted the floor in my shed (2 pack is the best option, but be careful as some 2 pack paints are very slippery and hold a static charge). The floor now has a lot of marks on it from the steel fab work I've been doing (work benches, shelving units etc). Not a big problem but the less damage you can do the paint the better in the long run
If you can get the piece between the 2 roller doors removalbe, this can give you flexibility with putting awkward shaped / sized items in the shed. It can be a good thing, although I never used the feature in the last colorbond shed I owned.
You might consider a couple of sheets of translucent roof sheeting to give you a bit of natural light. This lets in the heat too, but if you only have a single strip, it might be the best compromise.
I assume this is just going to be a workshop, or are you going to be parking your (and the missus) car in there permanently? If the latter, then the electric doors are fkn handy - it gets pretty tiring having to get out of the car each time you want to park it in the garage. If it's only for working on the cars, then don't waste money on the auto doors.
The size you've quoted is pretty good, although you'll find that no matter how big it is, it's still too small (my current shed is 18 x 8 and I'm still looking for more room).
The most important thing to think of - lots of light. Again, you can't have too much of this. I've got six double fluoro fittings in my home garage (12 x 9m) and it's nice, but could use more. Now I have the big shed, I don't work in the home garage anymore though (it's become a games room / gym / dance studio / dojo)
Hope some of that helps.
OK, I've built a few large sheds myself.
I purchased my sheds from Senior Steel in Shepparton, cheaper in getting the kit and engineering done all in one place from Rodney there. Tell him Jack sent you. The other place that does well engineered sheds is safety steel structures in Dandenong. You might want to do a comparison with those guys.
Steel prices are only going up, so $5k doesn't sound expensive - but devil is in the detail - what kind of columns and beams & thickness are they supplying (RHS vs c-channel?). Is it a clear span, or do they have knee-joints holding the roof beams up against the vertical columns? Technically you get what you pay for, steel just gets more and more expensive as time goes on. It just depends if you are dealing with a reputable shed company and you trust the guy on the other end. Make sure you get all the engineering drawings, council paperwork done, install instructions and they are easy to follow.
Windows are good, just depends if you are likely to be in an area where someone might use it to break in? It's nice to be able to look outside, have some natural light and open a window if you need to.
Use the rolls of foil bonded with fibreglass, in the roof between battens and the roof sheet. Best to do that install during construction - much harder doing it later. Most of the heat comes from the roof, so walls aren't as important.
Paint the floor after - installing the shed will wreck the paint if you do that first. Just use a 2-pack paint, my mate runs a tyre business and the 2-pack is really durable. I used the cheaper roll on stuff and it scratches way too easily (plastic storage containers can even scratch the surface of my floor!).
Cheers, will get a quote through those guys too.
Yeah just a workshop for my track car, and will be doing some vehicle wrecking/repair work in there as well.
So not frequently in and out of it.
Here's what's in the quote, I can post the drawing also.
MAIN COMPONENTS
ROOF CLADDING 0.42 Corro bmt - 0.48 Corro tct
WALL CLADDING 0.35 Corro bmt - 0.40 Corro tct
COLUMNS C15015 "C" Purlin, Fixed with heavy duty plates and bolts
RAFTERS C15015"C" Purlin, Fixed with heavy duty plates and bolts
PURLINS & GIRTS TS064.75 purlin fixed with heavy duty framing teks
GUTTER Quad
DOWNPIPES To ground level
As for joins, here's the gallery.
I shyed away from laser light sheets as I thought they were weaker (hail damage) and discolour and look shit over time.
The centre roller door section is not removable on this kit unfortunately as I did ask.
I know bigger is better but I only have so much space to work with, could go wider than 7m but then I'm into custom size territory and the prices seem to go up, this is the best kit I've found to fit my space.
+1 for clear roof sheets, at least a couple. Its good light for detail work.
Sounds cheap, how good is the metal?
I have a Stratco, expensive and sht service, but good steel.
And the clear panels are good quality.
Their foil insulation looks OK.
It seems they are using the bracing in the roof, and they are using c-section which is a bit cheaper. Cheaper cladding is thinner & some companies count the paint as part of the thickness!. Depends what your budget is at the end of the day and what you are prepared to pay.
I removed my skylights as I live in a bushfire area and lost lots of equipment during black Saturday because of it (fire burnt through). Not sure if that is a consideration for you. However light is really important, so make sure you put lots of flouro's in!
Expenses jump when you go over 7 and 9 meters. You shouldn't be in custom territory over 7 meters!
I'll see if clear roof sheets are an option, these kits seem cheap because they are bulk ordered with no flexibility.
Hadn't considered polished concrete, what is going to be more cost effective?
I want to minimise the dust and stop oil staining it. I usually put old carpet down also, at least under the track car lol
Have you considered polished concrete over paint?
Quite expensive to do polished concrete. Personally think it is overkill for a workshop.
I'd just do a smooth trowel finish. You can ask the concreter to do a high-gloss finish with the 'helicopter' tool.
Is that going to be any better than me just painting it myself.
Lower maintenance in the long run. It's just shiny concrete. Painted concrete will eventually need re-painting. Depends how fussy you are and what you want it to look like.
Personally I hate my painted floor. It just looks like it needs maintenance all the time. You can't touch it up as it looks patched up. Then again my mates two pack floor looks a million times better and it is in a commercial setting.
Oh yeah, make sure the concreter cuts expansion joints into the slab with a concrete saw. Don't let him trowel in a join, as you won't be able to run your trolley jack across the floor with weight on it (eg car or transmission).
Cheers, started getting some numbers for local concreters so should have some indicative pricing soon.
The real pain will be that wee can't get a concrete truck down there and it's 40m+ from the front of the block to the front of where the shed will be.
Good times ahead.
Good times ahead.
Pump, don't even think about wheeling it.
There's only double gate access down the side of my block, you'd get a car down there but not sure about a concrete truck, plus the weight would absolutely f**k my lawn.
Or is there some kind of pump I can hire are you saying?
As you can see I know SFA about concreting.
You might be able to get a mini mix truck down the side if you can get a car there.
Otherwise the concreter might charge more to wheel barrow the loads down the driveway.
Concrete pump is probably arranged by the concreter. Adds to the cost too.
7.6+ metres?
Don't think too many of you guys have wheeled concrete.
A full to the brim barrow holds 0.2 mtrs, well the first few do after that they hold less and less.
Hold the truck up filling barrows and you're paying waiting time.
Mini mixes, nope, not long enough chutes to do that job, you'll either be shovelling lots or driving on your reo.
Go the pump.
Yep, get the pump truck in. We built a new room (33sq.m) on the back of a house with very tight access and no drive-on a few years ago, and the pump meant the job to fill the blocks was over and done with in very short order. Can't remember the prices sorry but pretty sure it was only a few hundred. The concreter organised it himself.
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
