So in the end, the concreter sent a mutual friend around (unbeknownst to me, I just thought he was dropping in to see my shed).
we talked about the water issues and I showed him the random apron cut etc. He handed me $100 from the concreter who had said that he didn't want the hassle of dealing with me anymore (I guess those calls were annoying enough) and that he thought if he came around we might punch on (we probably would have as we had exchanged some very heated words on the phone when I told him what I really thought). So if our mutual friend thought what I was saying was fair to just give me the $100 for the weather strip.
I bought that GaraSeal one from eBay. It remains to be seen how well it will seal to the concrete sealer and grit additive. If it doesn't seal well I'll pull it up, strip back the sealer and put it down again. The supplier felt it would work fine as is but we'll see. I've also siliconed around the guides and bottoms of the flashings so when the next rain hits I'll know.
Here's an offcut of what the strip actually looks like.
What you see inside and out. That door rests on the outside of that hump.
I've tested pushing the Silvia over the strip and you feel it there but it's not that hard to overcome at least on a light car.
Fingers crossed no more water issues.
Edited by ActionDan
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
