Did you have the heater on when you were bleeding the system?
Did you put the thermostat in with the bleed jiggle pin the correct way up?
Did you replace the radiator cap?
The stock thermostat is 76.5 degrees so you've put a hotter one in. I would recommend using a genuine Nissan thermostat.
