Edit: Title says cold start, its all the time.. wont let me edit..
Took all the belts off and it still happens, replaced the belts, still happened.
My guess is the starter motor not returning. anyone have any experience / guess as to what it might be?
https://www.youtube.com/watch?v=SiQ1_qlZZ8Y
https://www.sau.com.au/forums/topic/430556-cold-start-2-second-grind/
Starter motor. Think the bush for the drive gear has to be lubricated. Theres a thread about it somewhere. Search for starter motor in tutorial/DIY section
Definitely starter motor, I've found lubing the shaft actually causes clutch dust to accumulate, and promotes this issue. Happy to be proven wrong.
I never saw any evidence that mine had ever had lube on it originally.
Contact cleaner, and flush out all the shite; then leave it dry.
  • 3 weeks later...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
