Okay so Ive got my 1999 r34 rb25de neo non turbo and lately I've been having some problems with taking off slowly at the lights without the car wanting to stall and also when sitting at a constant speed (cruising) it'll have a flat spot every now and then. Since having the problem I have done...
The iac valve has been cleaned
Maf cleaned
New coilpacks
New spark plugs
New fuel pressure regulator
Injectors cleaned
Ran awesome for about 2 weeks and now having the same problem. Searched many forums and websites but cant seem to get any decent information. Any ideas would be great full thanks.
https://www.sau.com.au/forums/topic/430558-flat-spots-in-rb25de-neo/
So I found out yesterday that the wrong plugs have been fitted to my car. Bkr5eix were fitted and the new mechanic said he is going to fit the iriway-7 (ngk) so hopefully this fixes my problem. Only thing is, is that the problem was happening before the plugs were changed but it will get a dyno done tuesday and will post the results. I thought about the throttle body but it was cleaned when the aicv was cleaned which sucks. Thanks for the feedback
The bkr plugs should be fine for your car. If the 7 on the end of the ones you are fitting refers to the heat range then they are too cold for your engine.
There isn't really a right and wrong plug for your car so to speak. There are ones that fit and ones that don't. And then some that will perform better than others.
Ahh okay fair enough makes sense. The guys down at signiture performance said that they were the wrong plugs and out of all of them they tested they seemed to work the best for the n/a's. Being that the plugs in it are designed for jap fuel or something?
Correct NGK plugs for RB25DE Neo N/A are PFR5G-11 Platinum or BKR5EIX-11 Iridium. Putting the wrong plugs in will make things worse. The 5 in both of these plugs is its heat range and shouldn't be changed unless you are running LPG.
Shaun. Iriway-7 are NGK racing plugs. Unless you have done a lot of work on your engine I dont for the life of me see why you would need them. Also a 7 is two stages hotter in heat range something I defo wouldnt do if it were me. If your running a stock Neo engine you could try decreasing the gap on your plugs to 0.8mm and see if it makes any difference. Those Iriways wouldnt be cheap either I will bet. Also just read your first thread again and am thinking you are confusing flat spot with a miss. Flat spot is when you accelerate away either from rest or through the gears and the engine dies then takes off. A miss when at a constant speed is as if you momentarily lose power sorta like if someone turned your ignition off then on really quick.
BTW the Iriways retail at about 38.00 or so each. They use them in the turbo versions so I guess they cant hurt. I would be checking every vacuum hose on your engine as well. It only takes a small split to upset everything.
Yeah car is still pretty basic at the moment. Well been a n/a anyway. I get what you mean I was just saying what I was told thats all haha. But I will take that on board and I dont really want to be wasting my money on stuff I dont need. And yeah with the plugs they were a tad too cheap especially for a n/a. From what you hsve said there I have both a flat spot snd a miss. Taking off from a stand still the car will want to die before it takes off. And at a constant speed the car will feel like its starving for fuel or something causing it to lose power. Im just running out of money very quickly on mechanics saying different things that are wrong with the car and it not working if you get what I mean haha:-/ but thanks for the feedback Neil its good talking to a real person that doesn't treat you like a 5 year old haha:-)
Hmmm looking through what you have replaced leans me towards fuel being the problem and not overfuelling but rather the opposite. Have you had the fuel pressure itself checked? How much mileage on the car? I would have your fuel pump checked if I were you. Also your O2 sender. Is it using more fuel than before? Also what fuel are you running?
Not exactly checked I've had the fuel pressure set because I've got the fuel pressure regulator. But I haven't had anyone actually check the fuel pressure... cars done 107000kms roughly and speaking yo a guy today said my cat could be stuffed or something similar. No actually its using probably the same amount of fuel as before and I only use 98 from bp or caltex. Haven't gone yo 7/11 or shell because I've had friends have major problems using their fuel.
@ Ravi those are the standard version of the platinum and iridium plugs. They would be fine except that they dont last as long. Main reason for using the others I reckon is because its such a bitch to change the plugs on a neo engine. Magna V6 engines have platinum plugs on the rear bank for the same reason . You have to dismantle half the engine just to change them.
Yeah the magna v6 requires the plenum to be removed to get to the rear bank (been there, done that).
Copper plugs still last pretty well. In the long run they can actually work out more cost effective than irridium or platinum plugs. From memory I got about 50,000kms out of the ones in my Commodore, and only replaced them because I was chasing a misfire (that new plugs didn't fix)
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
