THIS IS ALL I HAVE LEFT.
Please don't ask for anything else, PLEASE READ THE AD.
This is it, and I need it all gone.
Mint boot trims (NO CARPET.) - $100. (sides, covers, back panel, all in really good nic)
Firewall and plastic firewall piece. - $25
MINT CARPET. - $200
Japanese fuse box cover (interior) - $10
Gauge cluster - really good nic, 145xxxkm - $100
G Sensor - $100 (not red, still good.)
Stock AFM's - $40 each. (have 4)
Kick panels, rear lower side trims, main centre console piece, glove box lid, all in good nic - prices on request.
Coil packs ON ALLOY RAILS - $150 for the lot.
Factory intercooler, GOOD NIC - $150
"Spool" cam gears - $60 for both.
Alloy cam gear retainer bracket/C.A.S mount - $15.
C.A.S - $200.
Factory battery cover - $10.
Injectors on rail - $160 for the lot.
Front calipers (Sumitomo, worked fine, original) - $180 both.
AC pump and condenser and canister (all of those..) - $80.
CENTER ROOF LIGHT - $15 (good nick)
FRONT ROOF LIGHTS - $20
1003302_602844359760609_749431060_n.jpg971143_602844369760608_1381124455_n.jpg988244_602844493093929_2101352742_n.jpg992795_602844609760584_1756802911_n.jpg44529_602846066427105_195447538_n.jpg1011935_602846226427089_134162092_n.jpg64009_602846229760422_548952021_n.jpg1002838_602846316427080_1246201876_n.jpg1001661_602846673093711_768085701_n.jpg992908_602846736427038_1530265696_n.jpg1013562_602847203093658_1883678826_n.jpg1157676_622996151078763_712580266_n.jpg1005665_622996207745424_2074941224_n.jpg1150199_622996224412089_1263568091_n.jpg526855_622996227745422_777887288_n.jpg1175298_622996254412086_902364889_n.jpg1146744_622996281078750_1105239701_n.jpg1174590_622996367745408_1611000848_n.jpg
PIX.
IT ALL WORKS.
IT HAS TO GO.
AND IT HAS TO GO SOON!
Like seriously, I need the space.
Chop chop.
CHEEP CHEEP PRICEZ.
Wont post.
Sorry.
Hornsby Area.
Martin.
PM or text on 0431045486.
Edited by RBMunkie
https://www.sau.com.au/forums/topic/430564-last-of-32-gtr-parts/
Still got looms, mechanical minor stuff, coilpacks, two airflow meters, carpet, parcel tray, aircon gear, front brakes, some interior trim. Roof lights, eye level brake light, dash cluster, etc.
Hi,
I know you said won't post, but if you change your mind I will take the last 2 x AFM's off your hands.
Just throw them in a padded bag at the local post office and post, won't cost much at all.
Let me know if you can and I will arrange payment.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
