  • Replies 275
  • 3 weeks later...
So Fez and I have booked accommodation at the Mawson Lakes for Nats and are now looking at overnight stays for the trip there and back.
The plan at the moment is:
* 20th Sydney -> Mildura (10 hours)
* 21st Mildura -> Adelaide (4.5 hours)
* 25th Adelaide -> Wagga Wagga (9.5 hours)
* 26th Wagga Wagga -> Sydney (4.5 hours)
Who else is road tripping to Nats? Open to suggestions on route changes and accommodation.
Yep im road trippin from gosford, that plan sounds ok to me...
Would be nice to drive along with some others whilst im trailering my 33...
Im looking foraccommodation to share if anyone is interested both in sa and along the way
Great. At the moment I've book a 2 room apartment at Mawson Lakes for myself, Fez and Fez's GF but I can look at changing that to a 3 bedroom but we should have a couple of others coming down too who might want to share (hoping to catch up with Luke at the Texi on Monday to discuss). Once we have numbers and decide where to stay in Mildura and Wagga Wagga we can figure out the sharing arrangements for those stops (open to suggestions).
I think the 7-11 on the hume hwy after picton would be a good spot to head off from so that people can get through Sydney how they like. Suggested route for the first day:
https://maps.google.com.au/maps?saddr=Unknown+road&daddr=Wagga+Wagga+NSW+to:Hay,+NSW+to:Mildura+VIC&hl=en&ll=-34.292537,150.620327&spn=0.114167,0.161705&sll=-34.318062,150.524883&sspn=0.114132,0.161705&geocode=FSTh9P0dbJT6CA%3BFZkI6P0dkWDICClvn-CIR5kYazFQ70OQtAkGBA%3BFf9t8f0dLiOiCCkR7xklyX7gajHgJESQtAkGBQ%3BFaMN9v0dGNJ4CCnDmffsaQTDajHw1KAwpHkFBQ&t=h&mra=mru&z=13
Obviously you guys know i am out for this.... Its a shame as i was really looking forward too it but in this case something better came up ;)
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
