Hi Folks,
Interested in knowing if you HKS/Garrett GT30xx owners use an oil restrictor on your oil feed to your turbo ??
Like this (or simlar banjo attachment)
Reason I ask is that I am getting different info from various sources.
I am inclinded to think yes -
But putting restrictor on when not neccessary might be a BIG problem if caused oil starvation to the centre core.
Cheers,
  • Replies 50
I just went thru all this shit,I'd say yes to a restrictor,I don't know what size but all ball bearing turbos I know are restricted coz to much oil and they don't spool good and can piss oil thru seals.
I'm fairly sure it's a -4., 0.9mm hole (o.o35)
But need feedback from people who have done this and gone the distance with the restrictor in - not just daily driving - circuit and track work..
Cheers,
:P
In my skewed, often wrong opinion...
Double ball bearing turbos don't rely on oil pressure to support loads, and (GT series) have water cooling to cool the cartridge. So a high pressure/volume of oil isn't as vital - hence why I use a restrictor.
Edit: I think this applies to all HKS ball bearing turbos, and Garrett GT as well.
More info for you guys - I have an N1 oil pump - so more oil flow to the turbo.
I am getting puffs white smoke from the exhaust on decelaration from redline in 4th and 5th gears whilst the engine is in gear.
I have rung two Turbo specialists and both told me I didn't need one - but I'm not sure if they understood my circumstances.
Cheers,
Im also running an N1 pump on my car and have no issues with leakage?
http://www.gcg.com.au/technical/garrett%20...ng%20chra's.jpg
If you look at the top left corner of that sheet it has a little cutsection of a GT CHRA, you can see the very little oil passages, it needs heaps of pressure in the chamber above the nozzle to create an oil "spray" over the bearings, i dont believe with a restrictor you will have the same pressure in that chamber.
Id strongly suggest not putting a restrictor on these turbos.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
