There was something there yes - but not 1.2 mm more like 3-4mm - to line up with the original -4 fitting (in the pic)
I know white smoke could be lots of things - but I am troubleshooting from least cost to me forward.
WRT to your comment re HKS turbos being different for different applications - do you mean that I could have an HKS 3040 that was meant for a RB26 or a 1J or a rotor ?? How different can they be ??
Can you tell me someone I can take the car to that will give me a definite answer ? I will pay them - I've talked to lots of people about this and each gives me a different answer.
Cheers,
  • Replies 50
I see, I see... 4mm doesn't sound like a very useful restrictor to have, I understand why you're considering a smaller one.
Understood about cheapest solutions first troubleshooting :D
I have no idea what the differences are between the different releases, but I know the GT2530 for the RB25 is VERY different to the GT2530 for the RB26... I was just saying that to illustrate the point that if HKS were to goto the trouble of releasing different turbos for different engine applications, perhaps Sydneykid's theory of "one turbo to suit all applications" doesn't apply to HKS's range? dunno.gif Perhaps if HKS were to goto the trouble of releasing different turbos for different engine applications, their turbos might have restricted oil lines to suit each engine application? dunno.gif
Also another thing to consider, is... as far as I know, the N1 oil pump isn't a higher volume oil pump, as compared to a standard GTR oil pump (not sure about the GTS-t standard oil pump). All it is, is a higher pressure pump, but standard flow rates.... So if what I've researched is correct, you shouldn't have any extreme oil flow increases that might warrant restricting oil to the turbo any further? dunno.gif
I'm just throwing ideas around, none of the points I have brought up are concrete, they're just adding food for thought :D
The CHRA are the same, it's the housings/flanges that are different between the RB26/RB25/SR20 applications in the 25xx + GT-SS/RS range.
I thought the GT2530 for RB25 had that machined aluminium snout on the intake side?
Hate to state the obvious, byt have you thought about talking to Paul at BD4s, they are the HKS distributer, and build plenty of quick cars...only most of their clients dont typically advertise their power etc etc, but they have amongst others an MR2 running a 3240, an EVO IV running a 3037 etc etc, so have played with plenty of the GT30 based HKS range.
I was looking at the compressor cover a while ago and i could have sworn it had 3240 on it....i pissed myself laughing and all of a sudden the nitrous bottle made more sense....though the gas wasnt connected, dont know if it is now as i last looked at it before Xmas
Yeah - it might be obvious Roy - but since I didn't buy anything from BD4's , I didn't think it was appropriate to go asking them questions about stuff - I guess that is the way I am.
Business is Business....
However, if someone is friendly with BD4's and they are happy to help a poor unsuspecting customer - I'll take that :):mad:
You know what I mean , yeah ??
when i bought my new gt28 440hp i asked specifically when they made the braided oil feed if i needed a restrictor and both the guys at the shop said no in these sort of turbos (meaning garrett gt series i presume??) they have an inbuilt restrictor so suit the application.... but also on the other hand SK's comment about the varying oil pressures in different engines has me thinking.......though mine has been on the car for about 3000km without the slightest puff of smoke or problem with just a braided open line from the factory oil feed in the block to the turbo.......
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
