That it does.
Gearing such as close ratio boxes and holingers n diff ratios make a huge difference in how the car comes onto power. Example CRDs JUN and powertunes r34 gtr. But like you say Ash. Some people don't understand.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981064
Rb30's also love to rev if built right. Ask RIPS. he take a dirty 30 to 9-10k rpm without a fuss. It's just not needed in most cases because of the extra torque they make.
As for the to4z maybe it gets the job done. But today there are better options!
Josh.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981085
  On 21/08/2013 at 3:00 PM, LTHLRB said:
That it does.
I love the idea of going through 5 gears getting out my driveway. ..
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981118
inst the crower kit a copy of a spool kit wich was a copy of a nitto?
or am i f**king that up and the spools a copy of the crower?
either way one had shitty rod bolts in it i wich one escapes me at the moment this may be something look into
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981907
I have one of these kits in my R34 (not rb26, it's a gtt)
Note their kit which they market as being 25 or 26 compatible didn't come with pistons that suit the Neo head. I realise this thread is referring to the 26 but worth mentioning for anyone who uses the search feature in the future. I'm sure wherever you get it from can supply pistons to suit but I would definitely ask/confirm/double check/triple confirm before you order to be 700% sure to avoid drama.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981974
Hmm well I'm in the process of deciding to go stroker. I've heard things about mixing up the components from a step 1 and step 2 hks 2.8l kit. Or I will just dump my car at race pace and tell them exactly what is recommended based on my application/intended use. Interesting to see how 2.9 functions from a 2.8.
  • Like 1
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6982061
I'm sure Chris will sort it out one way or another. Last time I spoke to him, he was doing his own 2.8 kit which I believe is in his car right now. As far as the 2.9 goes, these things need all the stroke they can get. Every little bit counts! An extra 1.3 mm is an extra 32.5% more stroke than going from a 2.6 to a "2.8" kit. Bring it on I say :D
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6982383
That it does.
Thanks guys , I think I will be getting this, Speaking of the powertunes R34 gtr , spoke to the guys there who speak highly of BC obviously as they sell it but that GTR is reliable uses B C stroker makes over 1000hp been doing it for 3 yrs been driven heaps even gets street driven and no issues what so ever.
I also spoke to a few other people who have used his stuff with good comments and no issue, read a few posts of ppl who speak highly of them, I will use a new N1 block as a base, strengthen it everyway possible, do lots of headwork, should be good. Will do some more homework offcourse It is not going to be a rushed thing.
Cheers.
Edited by GTRAAH
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6983395
The bc stuff I do hear good things about.
Dont quote me but im sure boost logic are using at least one of their cranks in a 7 sec supra. Will have to find the build again to be 100% sure.
But plenty of guys using them in 2jz's stateside at more than 1000hp with no failures that I have heard of.
  • Like 1
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984180
You either need a shorter driveway or think about parking half way down....
Cheers.
The powertune guys seem to know whats what when it comes to bc and rb's. Best of luck with your engine building mate.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984393
Just thinking about it gets me all excited to do this a lot faster! I guess you've lived and breathed 2.8's far too long ey Piggy? Chris knows his stuff, I'll let him do the hard work lol
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984407
Haha. Well the difference in drive ability and twist between a 2.6 and 2.8 is night and day, lets not even go to a 3.0 or bigger. It baffles me that anyone would consider using a standard stroke length crank when you have it all apart. I realise its more exxy but you get a much better result.
If I didn't have my stroker crank and block, it'll be bigger without hesitation.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984452
Yea I get what you mean, if my engine was apart I would have my engine bored and longer stroke length. The results are just more crisp and can do so much more. Want to chuck some -5's on there with 25-26psi on E85 and aim for high 400's
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984534
I quoted you.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6985389
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
