That it does.
Gearing such as close ratio boxes and holingers n diff ratios make a huge difference in how the car comes onto power. Example CRDs JUN and powertunes r34 gtr. But like you say Ash. Some people don't understand.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981064
Rb30's also love to rev if built right. Ask RIPS. he take a dirty 30 to 9-10k rpm without a fuss. It's just not needed in most cases because of the extra torque they make.
As for the to4z maybe it gets the job done. But today there are better options!
Josh.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981085
That it does.
I love the idea of going through 5 gears getting out my driveway. ..
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981118
inst the crower kit a copy of a spool kit wich was a copy of a nitto?
or am i f**king that up and the spools a copy of the crower?
either way one had shitty rod bolts in it i wich one escapes me at the moment this may be something look into
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981907
I have one of these kits in my R34 (not rb26, it's a gtt)
Note their kit which they market as being 25 or 26 compatible didn't come with pistons that suit the Neo head. I realise this thread is referring to the 26 but worth mentioning for anyone who uses the search feature in the future. I'm sure wherever you get it from can supply pistons to suit but I would definitely ask/confirm/double check/triple confirm before you order to be 700% sure to avoid drama.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6981974
Hmm well I'm in the process of deciding to go stroker. I've heard things about mixing up the components from a step 1 and step 2 hks 2.8l kit. Or I will just dump my car at race pace and tell them exactly what is recommended based on my application/intended use. Interesting to see how 2.9 functions from a 2.8.
  • Like 1
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6982061
I'm sure Chris will sort it out one way or another. Last time I spoke to him, he was doing his own 2.8 kit which I believe is in his car right now. As far as the 2.9 goes, these things need all the stroke they can get. Every little bit counts! An extra 1.3 mm is an extra 32.5% more stroke than going from a 2.6 to a "2.8" kit. Bring it on I say :D
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6982383
That it does.
Thanks guys , I think I will be getting this, Speaking of the powertunes R34 gtr , spoke to the guys there who speak highly of BC obviously as they sell it but that GTR is reliable uses B C stroker makes over 1000hp been doing it for 3 yrs been driven heaps even gets street driven and no issues what so ever.
I also spoke to a few other people who have used his stuff with good comments and no issue, read a few posts of ppl who speak highly of them, I will use a new N1 block as a base, strengthen it everyway possible, do lots of headwork, should be good. Will do some more homework offcourse It is not going to be a rushed thing.
Cheers.
Edited by GTRAAH
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6983395
The bc stuff I do hear good things about.
Dont quote me but im sure boost logic are using at least one of their cranks in a 7 sec supra. Will have to find the build again to be 100% sure.
But plenty of guys using them in 2jz's stateside at more than 1000hp with no failures that I have heard of.
  • Like 1
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984180
You either need a shorter driveway or think about parking half way down....
Cheers.
The powertune guys seem to know whats what when it comes to bc and rb's. Best of luck with your engine building mate.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984393
Just thinking about it gets me all excited to do this a lot faster! I guess you've lived and breathed 2.8's far too long ey Piggy? Chris knows his stuff, I'll let him do the hard work lol
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984407
Haha. Well the difference in drive ability and twist between a 2.6 and 2.8 is night and day, lets not even go to a 3.0 or bigger. It baffles me that anyone would consider using a standard stroke length crank when you have it all apart. I realise its more exxy but you get a much better result.
If I didn't have my stroker crank and block, it'll be bigger without hesitation.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984452
Yea I get what you mean, if my engine was apart I would have my engine bored and longer stroke length. The results are just more crisp and can do so much more. Want to chuck some -5's on there with 25-26psi on E85 and aim for high 400's
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6984534
I quoted you.
https://www.sau.com.au/forums/topic/430618-rb29dett/page/2/#findComment-6985389
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
