Hey guys I've just recently put 19x11+20 on the rear of my V
And every time I go up a kerb or a high driveway the inside of my rear wheels scrub against my coilovers causing the locking collar to come loose.
Just wanting to know if anybody have the same issue with similar or same size wheels and is there a way to fix.
Thanks for your help
https://www.sau.com.au/forums/topic/430650-wide-wheels-scrubbing-on-coilovers/
LOL... not sure if anyone has put 11inch wheels at the back.....
But to fix your problem, you can try using spacers to space your wheels away from your coils, but your wheels might either stick out of the guards or be rubbing against your guards...
PS... You can always try some narrower wheels...
Mines on coils with one of the collars removed, lipped rear guards, camber arms and a bit of tire stretch to make it all work without rubbing. The front is not as easy though. Brake & swerve or crazy angle & take you time seems to work best for me.
Check the geometry of yours, the top of the wheels cambers in as the suspension compresses, how much clearance do you have to make? With enough room to the rear guards, you may be able to run a small spacer depending, but they aren't ideal.
Good luck
ร—
ร—
