God_speed has a V-Spec II Nur too Chris & it came here to Aust with just a few hundred Kms on it.
Plastic was yes, still on the seats/doors.
When it's out again and we're together, you're welcome to check it over.
Pristine like yours :)
https://www.sau.com.au/forums/topic/430664-wow/#findComment-6983569
Photos just cannot show how clean his car is. Immaculate and an awesome find!
https://www.sau.com.au/forums/topic/430664-wow/#findComment-6984179
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
    • So when will the Samsonas, twin scroll turbo setup on go?
