Hey,
I picked up a helmet today - Revolution Racegear currently has a sale till the 26th June or something so I got a full face graphic (riced heh) for $135 supposedly down from $220.
Anyway, now the next thing to do is the secondary bonnet restraint.
I spent a fustrating 10 minutes just staring at the bonnet closed to see how I could do this and could not come up with anything.
I know you can use webbing strap and then tie it to the toe hook, but I couldn't see where you could attach this to the bonnet?
I prefer if there could be some form of "hook" fixed to the bottom of the bonnet, that I could latch onto the frame - IE have it latched all the time to a) prevent bonnet opening even on the road and B) to take a thief a few more sec to open the bonnet.
I tried thinking of how to do this too, but there isn't many holes in the bottom of the bonnet and not many place for a hook (that you can reach with the bonnet semi-closed (ie lever pulled but still latched).
Does anyone here have any pictures of how they've done it? If it helps its for a S1.5 R33.
Thanks :P
https://www.sau.com.au/forums/topic/43067-secondary-bonnet-restraint/
Hey fooey, the most permanent way to do the secondary restraint is bonnet pins
Temporary option is to use something like rope or a belt to hold it in place. I've done both, basically you run it through one of the holes in the bonnet reinforcing and then down through something below, I used the whole front bumper. sorry no pics that explain in better but its pretty straightforward.
Another neat way is to use some braided stainless steel cable. Attach one end to the radiator support mount, then other to the latch on the bonnet.
Then to connect the two pieces, have a loop on one ned of braided line, then the other just have a clip. Easier way is to just have clip on the end of the braided wire attached to the radiator support mount, then clip it to the male part of the bonnet latch, clip it up, then close the boonet...you only need the braided wire to be about 4-5" long.
best way for a road car
i found
was use the old compliance seat belt
just cut the belt and attach the latch to the radiator crossmember near the headlight and brap the buck around the bonnet
so easy and then you just unclip it like a seat belt
neat and practical
pete
...ummm no pics, but stainless steel braid, with the approved fitting that gets clamped onto the braid is good for HUGE loads, I cant remember what the tensile strength is, but needless to say the equivelent road speed from a bonnet lifting would be way higher then any car can go. It will easily pass the scrutineering for a CAMS Supersprint etc
I know where to get it in Sydney, but down here in Melbourne ill be struggling a little, hardware stores sell the braid, but i doubt they will sell the fittings that clamp on the braid after you have doubled the braid back on itslef to create a loop.
As for the clips just a stainless clamp or one of the clamps off an old / expired harness that clips to the eye bolt ... i need to get one for the my bonnet before July 8, so if anyone in melb wants i can probably get 3 or 4 made up by a stainless braid place i pick out of the yellow pages, may even work out a buk fitty cheaper if i get a few.
I was thinking of using one of those "toggle" bolts and either:
a) bolt a hook (to hook into a loop of cable on the radiator mount)
B) bolt a loop (to hook into a hook on the radiator mount)
Roy, if your method works (as I'm having doubts how to do my way) I don't mind going for one too, as long as you inform me what other parts I need to get (if any) to complete the job.
Hey,
Thanks :D
I had a bit of a look there yesterday myself and cant believe that helmets can get up to $2000.
Alan
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
