Hey ive got some 400R skirts and rear GTR pods off my old car which i want to install on my new one. My old 33 had the holes drilled etc and brackets to fit the pods which wrap around the rear bar, but my new 33 has never had any after market kit on it; therefore im looking for ways i can do the install.
What would be the best way to mount the side skirts? ( i dont want to only use sikaflex etc ... needs to be secure )
And how do you mount GTR pods on a GTST? (doesnt seem to be much info on this? is a "glue" the only way??)
Any help is appreciated . But preferably i'd like some detailed steps :D
Car is a series 2 :cheers:
https://www.sau.com.au/forums/topic/430681-how-to-fit-bodykit-o/
I'd go sikaflex first (Held into place with clamps) and once set, screw onto the brackets/holes..
Had to remove my bodykit when I bought my skyline with a Stanley Knife... and really thinking of trying to NOT use ANY sikaflex so I can easy clean under my skirts etc..
Not sure if its possible while keeping good strength..
Edited by Zrobe
some factory skirts come with the plastic clips.
skirts I fitted to mazda 6s were like this.
if you done the holes right, no bonding agent needed.
I never used sikaflex on them, and didnt get any coming back.
  • 1 month later...
The skirt is completely fiberglass with no clips or anything. Have decided to paint them, then use a little bit of sikaflex at the top of each skirt so i can let that dry, then angle them. Once im happy im just going to drill a through the marked hole in the skirt (so, technically the body) and then bolt them to the car (once ive found/bought some good nuts/bolts etc)
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
