Wrecking r33 Gtr vspec
Midnight purple
Everything available
Rb26dett engine from a r33 Gtr vspec, motor has done approximently 10000kms. I have pictures of recent cold/dry compression test and videos of the engine running can send or show to serious buyers only.
**Can fit and install for extra by mechanic locally on the Gold Coast pm for details**
Compression 160-165psi across the board
Bottom end
R33 Gtr crank
N1 block
Cp pistons and rings
Eagle rods with arp rod bolts
Arp mains
Arp head studs
Greddy oil pump
N1 water pump
Tomei oil restrictor
ATI balancer
Top end
Tomei Poncams 260deg 9.15 lift in and ex
Greddy cam gears
Head full recoed etc
Brand new rocker cover seals and half moon seals
Painted r34 Gtr red covers
Price $9500
Depending on buyers can include standard injectors and turbos for extra
An also supply hks gtss turbos, sard 800cc injectors and power FC Ecu for extra
R33 Gtr brembo brakes and rotors
Front and rear
Great condition
$1500
R33 Gtr rear seat
Great condition
$180
R33 Gtr door cards
Front and rear in great condition
$300
R33 Gtr bonnet
Great condition
$600
R33 r32 Gtr power FC and hand controller
Great condition
$750
Sard 800cc injectors for rb26
Great condition
$500
Hks complete suction kit with hks pods
Includes inlet and outlet pipes
All hot side piping
Great condition
$650
Hks Intercooler hard piping kit
Great condition
$280
R33 nismo Gtr speedo cluster in black 320km 11000rpm
Great condition
$480
R33 gtr fujitsubo cat back exhaust with cat
$250
Rb26dett fujitsubo tuned length front pipe
$150
Hks gtss turbos
Great condition
Only ever run on 15psi
$1600 turbo and actuators
$1700 full hot side
R33 Gtr engine wiring loom
$180
Blitz boost controller sbc I-d
New model with the little screen
$250
Blitz power meter I-d
New model with screen
Matching to above
$200
Gtr boot no wing
$90
R33 Gtr drivers window switch
$80
R33 Gtr drivers side window reg and motor
$60
R33 Gtr centre gauges
$90
R33 Gtr v spec diff
$200
R33 Gtr rear 6 bolt shafts
$100 each
R33 Gtr rear hubs with hand brake assembly
$190
R33 Gtr v spec rear bracing under subframe
$90
R33 Gtr v spec bracing that goes under front of gearbox
$80
R33 Gtr abs unit
Great condition
$180
R33 Gtr rear bar
Midnight purple great condition
$90
R33 Gtr front reo bar
Great condition
$100
R33 Gtr spacers for front guards
$60
R33 Gtr genuine front strut brace
$70
R33 Gtr genuine rear strut brace
$70
R33 Gtr boot brace
$60
R33 Gtr ignition barrel and locks
With key
$150
R33 Gtr steering wheel and air bag red stitching
$150
R33 Gtr master bm57
$190
R33 Gtr clutch master
$70
R33 Gtr drivers headlight
Great condition but has 2 broken mounts for grill
$100
R33 Gtr dash
$60
R33 Gtr surround with hazard lights etc
$60
R33 Gtr front drive shafts
$80 ea
R33 Gtr boot trim
$80
R33 gtr radiator
$70
R33 Gtr bovs with recirc stuff
Complete set up
$180
R33 Gtr Intercooler
$100
R33 Gtr bonnet latch
$30
May have missed stuff let me know what your after
Gold Coast Nerang
0487924497 or 0414596256
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
