My first suggestion would be to have a very good close look for leaking vacuum hoses and fittings.  There are lots, so take your time, a small split in the underside of a hose is hard to see if you rush.
Slightly off topic: Is their something I can spray/do to the hoses to see if their is a vacuum leak? What is the easiest way to find a vacuum leak?
I can hear a soft hissing near the fuel regulator which sounds like a vacuum leak that i've never heard in the last 18mths.
Soapy (dish washing liquid) water is good, if there is a boost leak it blows pretty bubbles :flower:
For a vacuuum leak, try some RP7, the engine will suck it in and the idle rpm will jump. :)
hmm...i am having over boosting problems with the stock boost solinoid, hits 10 most times, whats going on? could a hose be ****ed? or is it the solinoid? when it hits past 7 is when it starts the flat spot pretty much... also the flat spot goes away after bout 6 grand because the boost goes back down to 7. ..real wierd...any thoughts?
ok fellas after being annoyed for a while
we got energetic last sunday and borrowed a mates 33 in top running order
we changed plugs,packs, fuel pump, ecu, fuel regulator, fuel return valve, blew out the fuel lines, afm, air filter, o2 sensor, coil pack modulator, adj cas, checked tps
we tried clamping the fuel line which jumped me up 30 odd hp so we were obviously getting to much fuel, we adj timing and bingo no more missing although thereis still a huge hole in the power which is soon to be fixed with safc. but we figured that timing belt is screwed and has jump a tooth or something so i am going to do 100k svce next week, and replace cam gear whiile i'm there. lucky we have access to a dyno so did it on the cheap
started out with around 128-130 rwhp endedup with 195.5rwhp.
looking for around 240-250 with fmic safc and cam gear!
one other thing to check is do a simply diagnostics test via consult plug. I had a very nasty hole (to the tune of about 80RWHP) at 5,500 - 6,500 due to my knock sensor (Code 34) not being connected properly and my stock ECU retarding my ignition levels to safe amount, then all of sudden, power jumped back up again, all with consistent A/F's and boost levels. Plugged in the knock sensor, reset the ECU and been happily boostin ever since. Go the S-AFCII :cheers:
  • 11 months later...
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
