  • Replies 96
Any workshop that has a Z tune is serious about Skylines; publishes all their tuning figures online; holds Skyline's Australia nights and is willing to back themselves and tune a Lamborghini Gallardo custom twin turbo set up (pretty confident tuner). Very confident that Adam at JEM knows his stuff.
so, by your summary, every other workshop isnt serious about skylines because they dint have a z tune?
considering there were 20 z tunes released, I dont see how all the serious skyline tuners could own one.
I don't know how you came to that conclusion at all lol.
Ummm... "unique" take on one part of what I said. I thought we were talking about the better tuner and the reasoning to this little portion of my entire comment is that they are passionate about Skylines. In fact, passionate enough to source a bona fide Z tune, which is "one of the most" serious skylines out there. My experience... passion drives performance. Put as a simple analogy, would you hire someone that turned up to a job interview in a flannelette shirt (Don't answer it's rhetorical)
Edited by TREGTR
envy did it last tune
For what it's worth that figure with those turbos... the poor little things would have been choking for air. I had my R33 Gtr tuned there back in Brookvale days - boosted hard but the oil pressure light kept coming on and I had to back out. That was -5s 320kw. What boost did they get the 460kw figure at and was the knock sensor and oil pressure sender still attached?
Edited by TREGTR
Good choice. Technically not an argument when only one side though.
i think the next tune going to b jez but he is so far for me whats the address to this guys shop and number
I have no affiliation with either? Once you go to both, you'll be able to tell us which is "best" in your opinion.
Edited by TREGTR
Most definately can be achieved. Not easy though. Not sure what the oil pressure sender has to do with a good -5 result. :/
Interested to see a dyno sheet. No sender no oil pressure, usually follows no knock sensor Edited by TREGTR
Why so much doubt? There have been a few results that have done those numbers on -5's.
Hey mate my old dyno sheet is up in rb26 dyno results
My post numbers are pretty low and I haven't quite figured out how to access this info. Are you able to help me out with where to find it?
I recommended JEM, perhaps, in retrospect, I should have just put: JEM +1 without any reasons or ellaboration as to why I would recommend them to help you out. If you look back over other comments none have provided reasons, I did. I also did not say they were better, as I have no experience with DVS.
The dyno figure seems high that "Envy" provided for -5s, coming from a qualified mechanic that has built a few. In fact, one of my builds is going to JEM next week that is extremely similar to what you have, hence the interest. Also, from past experience there is a lot more to a good tune than just an outright Kw figure. My intention was to draw the focus away from the outright figure, as this often leads to disappointment when there is no longevity factored into the tune for a street car where your expected outcome "is not 460kw but higher" on that set up.
The intention was to assist - the responses make me wonder why I bothered in the first place. Welcome to SA for the new guy! :/
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
