Car:1996 R33 GTS-T Series 2: White
MODS:
HKS Turbocharger
HKS POD Filter
HKS Monster Sized Front Mount InterCooler And Piping
Bosch 044 600HP Intank Fuel Pump
Blitz 3.5 Inch Turbo back exaust with 4.5 inch muffler
HKS SSQV BOV
Chipped ECU
Cusco Strut Braces Front and Rear
Bleed Valve
Blitz Turbo Timer
Nismo Quickshifter Kit
LOOKS:
BOMEX front bar
Nismo 400R Sideskirts
VaV 17x8 inch Mags
INTERIOR:
APEXi Boost Gauge
GReddy Temp Gauge
Trust GREX SYSTEMS Gear Knob
Razo Pedals
SOUND:
Kenwood M505 MD head unit
Kenwood C505 CD Unit and Equalizer
Kenwood Rear 3 way Splits
JBL font woofers and tweeters
How powerful u guyz think this is?
https://www.sau.com.au/forums/topic/43077-guess-the-power/
  • Replies 40
I think the pedals, gear knob and dual head unit would push it to 231kw @wheels ;)
you're forgetting the bomex front bar and 400r side skirts are an extra 20rwkw each!
seriously why do people do this? (listing mods which have no effect on power).
we need more details like
- what turbo
- what front mount (specs)
- boost level
https://www.sau.com.au/forums/topic/43077-guess-the-power/#findComment-879628
Interesting. . . Do you know how much it would be with the 400R rear bar instead of front bar? It has 3 layers of paint to so gotta take that into account...
https://www.sau.com.au/forums/topic/43077-guess-the-power/#findComment-879853
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
