I have acquired a front cut and a stack of rear end parts that is basically taking up space in my driveway so it's all gotta go.
Prices are very fair already but if you'd like to make a reasonable offer feel free. Bear in mind if I have to package and post the item I may be less receptive to low balls.
MORE PICS AND PARTS TO BE UPDATED AS I GO!
Pick up Lower Blue Mountains Sydney.
Bonnet $100 (pick up only at this stage)
Doors $50 each (pick up only)- Driver's door sold, all others still available.
Side mirrors $30 pair or $20 each
Door cards- not in good condition however the fabric parts could be used to upgrade your existing trim- $Make an, offer pick up only
Rs260 (series 1- red trim) door card set in awesome condition $sold
Rs260 )series 1- red trim) front seats $200 pair,
Front guards $50 each (pick up only)
Passenger inner guard liner $30 (pick up only) Driver's side sold
Rear tailgate, complete except for boot lock $150 (pick up preferred)
Dolphin side skirts and rear bar, would need some repairs $SOLD
Block $200 (head sold already, motor had low compression on 6)
Op6 turbo $SOLD
Gearbox $SOLD
Manual conversion $SOLD
Steering wheel (manual with airbag) $150
Wiring looms $50 each
Rear diff $400
Driveshafts $100 each
Hubs $50 each
Rear brakes $50
Complete rear cradle (diff, shafts, cradle, hubs etc) $600
Front brakes $80
Brake master and booster $40 each
ABS unit $80
Fuel pump/cradle $50
Stock suspension with lowered springs $SOLD
Headlights- Passenger side only available $50
Everything else you can see is for sale, make an offer!
Sold already:
Head, coilpacks, intercooler, front bar, drivers side driveshaft, rims, centre console, power steering pump, 4wd pump, driver's door, drivers side inner guard liner, washer bottle.
  • Replies 60
Posted Images
Hey! I am after the two drivers side doors.
I believe they'll fit an S1. Only downside is, I'm in Melbourne. Can you let me know how much it would be to ship to Postcode 3147 in Victoria?
Thanks
Thanks
hi mate, i should have put this in the thread but would prefer pickup on the doors as they tend to get damaged in transit.
First post updated, some parts (mainly panels) are a kent to wrap and post so at this stage they are pick up only. All other parts I'm more than happy to arrange shipping at cost.
How good is the bonnet? And headlights and are they xenons? Shocks good?
bonnet is pretty good
yes they are zenons
shocls cant say as the car was chopped in half and sent from japan
Hi mate what condition is the rear tie rod ends in?
tie rods are now on my stagea so gone sorry
no chance you have spare keys do you?
Comes with the door locks and ignition barrel
passenger side headlight, if willing to post to sa 5114 and whats the condition? thanks mate
Little bit foggy but pretty good ill get some pics
Ecu still there?
Yea mate 100 delivered
Pm me your bank details and ill send you money and address etc
Thanks mate
You will have 2 excuse my ignorance, by the looks of it it is a 2wd gearbox?
Also what do you know about the diff? Ratio ? Mechanical ?
Gearbox is four wheel drive, diff is 4:4 viscous
can you chuck up some photos of the door cards please dude
Rs260 cards or the stock ones?
How much for the shocks?
150. Stock shocks with lowered springs
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
