  • Replies 60
Posted Images
Do you have the Rs4S door trims and carpet? Also looking for an S2 left rear tailight.
No carpet, I have door trims but ill have to double check condition. Tail light I do have. Flick me a pm if you're keen.
hey buddy still have the headlight height adjustment switch (on dash to the right of steering wheel).... how much buddy i live in miranda, keen to go for a cruise up your way.
also the door light sensors (little rubber block things)
and the front rotors...are they in good nick or ?
have u got a set of rear lowering springs, shocks? cheers buddy
nah sold already
Hi there Fatz,I'm after the front passenger side headlight that you have, would it be possible to ship it to WA.
Cheers
yup, happy to post. Will flick you a PM
Do you still have drivers side mirror for sale
Also do have the BOV return pipe for sale
mirror- yes, will check on the return pipe and let you know
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
