As the title states im looking for a clutch to go on my r32, its having a 25 conversion soon and im looking to get this power, what clutch do people recomend? I will be doing the 25 box conversion soon, but using the rb20 box for the mean time, yes i know its not ideal, but it has to do until i get one. It will be a street car, with the going to the track when i can and the usual skid around "industrial areas"
I did try a search before but didnt find what i was looking for.
https://www.sau.com.au/forums/topic/430838-clutch-for-300kw/
City driving pussyfooting 300kw? or actually driving the car hard 300kw? id personally go an ORC or OS GIKEN twin plate sprung centre for a very long clutch life (unless you drive like a pig and clutch the absolute hell out of it) or ring jim berry. OR if you dont want to spend that amount of dough and arent planning to drive the car to its limits for extended peroids.. flick through the exedy catalogue or xtreme.
  • 3 weeks later...
I have a 1996 GTST putting out 276rwkw aiming to get it to 340+ rwkw
using NPC metal button clutch ,engagement of clutch is quite aggressive
been advised by NPC it should handle 650+ Hp
When I first did my engine (273rwkw) I got an Extreme Extra HD clutch (as was suggested by the workshop, as I found out later only because they had a 'deal' with them) - the thing was horrible. So bloody heavy you needed a tree trunk of a leg to even depress the thing, and after about 6-9 months of, let's say 'spirited' use on the street, the thing decided to weld itself to the flywheel one day - I managed to get it off again but after that it carried on like you wouldn't believe (not surprisingly), grinding and making noise etc. Suffice to say, never again will I own an Extreme clutch!
I ripped it out and after reading some very good things rang Jim Berry (i'm in Adelaide) and organised (after a mammoth phone call) for him to rebuild it using the existing pressure plate and organic plate, and have it shipped down here to my workshop. Now, I may be the only person to have a bad story about Jim Berry, but when the clutch arrived, it didn't fit! It went into the car, but it wouldn't disengage completely, and you could barely get it into gear. So out it came, and back to Jim it went, only to comeback a week or so later, and guess what? Not fit again! Jim was totally bemused by this, as were my mechanics, and as the issue dragged on and my car sat in the workshop (and this is my daily drive!) useless, I got pretty annoyed! Third time lucky? Nope. Still wouldn't fit. Finally we gave up, Jim refunded the money and cost of the time wasted (very good of him) and the workshop put in an Exedy heavy duty cushion button ceramic.
Now 2 years later and running E85, making 300rwkw and driving the thing pretty hard (although no track time) the Exedy hasn't missed a beat. The thing grips like you wouldn't believe, so it took a bit of getting used to, especially since it feels (from memory) no heavier than the OEM clutch. Bear in mind though with a ceramic clutch it is pretty on/off - if you release it SUPER slow through the friction point you can take off pretty smoothly, but if you're not paying attention for a moment and let it out without enough revs it will jump your arse forward pretty violently and stall! Now that I'm used to it though it's great to drive, and holds my power easily. The only other annoyance of a ceramic clutch is not being able to ride it at all - especially trying to reverse uphill - after a few seconds of slip the thing will start to grind pretty badly - however it's fine again as soon as it cools down after a moment or two.
The fun thing is trying to watch what I like to call a 'normal' person jump in and try to take off with it - usually results in a number of stalls and some laughs from me.. ;-)
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
