Yeah if you could find out that would be great? Is he running an external gate?
Reading this it looks like you can keep the factory cooler piping, I know the piping before the turbo will need to be changed.
Do you know if the crossover pipe is still used for high mount set ups?
This can be done on the "cheap" but really the not the best way to go. Turbonetics would be the cheapest Turbo I would go, just buy it from them or a dealer and cheap manifolds HAVE problems i;e put a straight edge on it and you will see. So the items you will need and the usual mods to be done for this setup ON A STANDARD RB25DET in a Skyline are:
Turbo
Manifold
Wastegate
Injectors
Manifold Studs
Wastegate Fabrication
Dump Pipe Fabrication
Intercooler Pipe Fabrication ( If using a Front Mount)
Intake Pipe Fabrication
Fit Injectors + Rewire Loom and Pressure Test Fuel Rail
New Oil Supply and Drain System
Mod Plate for High Mount
New CPU or Map / Dyno Time
Heatsleeve
Z32 Afm with Tomei Adaptor
Upgrade the Clutch
New Vacuum Hose
Clamps + New Brass Fittings
Coolant
Tow Truck Fees
There is more shit but CBF typing it.
With the Turbo + manifold with custom work and Sard Injectors added onto the price I did it for about $5530, and that was on the cheap lol.
Edited by Mr.H
Thanks man, feel free to text me the details, 040 264 6066
Turbo
Manifold
Wastegate
Injectors
Manifold Studs
Heatsleeve
Upgrade the Clutch
New Vacuum Hose
Coolant
Tow Truck Fees
wow thanks for the info, will have a good read of this.
Ok so everything you mentioned iv already taken into account except for the intercooler fabrication & the mod plate. So might as well go high mount unless Bunta's friend has the right low mount manifold for sale.
I pmed you the details not sure if he wants to sell the mani seperate. But for the price he is offering you effecively get the manifold, pay 500 bucks less than retail for the turbo them all the piping the dump pipe and waste gate come free!
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
