Hi everyone and thank you for your advice
I have just finished speaking to a fella over here in Perth who used to work for 101 garage in QLD
Looks like I will probably go with the Haltech unit and the 3073 turbo on top of a 6 boost manifold.
I didn't realize that running E85 was that much of a mess around ( excuse my ignorance)
Will use the AFM to pass licensing and then run the internal MAP sensor in the ecu.
The engine exhaust noise shouldn't be too much of an issue as long as its gone properly.
Most probably won't be pulled over every day like you do in a skyline majority of 5 O wouldn't expect that from an old fj holden
Sounds like a potent setup in the making, look forward to seeing how the HTA3073 goes... Should be very responsive!
Would love to play with Haltech sometime, sounds like they are good products but G4 Link dominate here... For good reasons, but not necessarily that they are the best
Good points there to consider there, only going by what was recommended to me with the turbo size, thank you for the advice and I will do some more research when I get back to the big smoke, if I can go a smaller turbo and pick up good response then that's great, not after huge HP just some decent HP so the car is fun to drive.
If Fitting the AFM to get past licensing then running the MAP sensor part of the ecu after is what I have to do then I will do that no big deal.
Running E85 was only an option to get past the emissions part of licensing due to the fuel burning cleaner if it was needed, once car is licensed I was going to run premium pump fuel.
Ok so I have a few mates that build Rb's and I have spoken to RIPS over in NZ because I was looking at one of their manifolds at one stage and some fellas that have drift cars.
Recommended so far
Haltech
Wolf
Power FC
Link G4
What about a Vipec man ! ?
Link manufactures the ViPec so its the same ECU essentially.
They're actually not. The Nissan plug in boards are quite different. The VIPEC plug ins have quite a few features that the Link plug ins don't .
Yes true. Built in Knock boards on the ViPec being one of them. Along with a few other small features. But they are a very similar platform. Software is almost identical with few small differences between the two. The ViPec does however support Peak and Hold Injector drivers. But i really don't think that is such a big issue nowadays. There are that many different high impedance injectors on the market at a reasonable cost, there is no real reason that you must require a Peak and Hold Injector capable ECU.
The Link is cheaper. And now with the release of the G4+ the differences are closing up. The G4+ now has built in digital knock control.
I'm sure if you scurried the Link forum you'd find a thread with all the differences between them.
Yeah good plan... haltech and 3073 will be a good combo.
After the initial rego and engineering inspections, you would be left alone pretty well. More likely to be pulled for cops to have a look than a ticket.
Well that's the plan anyway, I do find that being in my early 40s that I rarely get pulled over, probably got something to do with the fact that as you get older its harder for them to BS you.
I feel for all the young fellas out there who go and spend good coin on a nice car only to be goated and harassed by the boys in blue.
Majority of engine builders that I have spoken to recommend the Haltech with either the 3073 or 3076
Thank you everyone for your advice and input
Cheers
Paul
Built in knock sensor, on-board MAP sensor, ignition outputs for each cylinder, etc.
Not a lot of differences no, but I do think they make the ViPEC a bit better value than the Link. Especially when you consider that with the Link you need to pay for an IAT sensor as well, and if you want to run any decent boost then you will need to splash out on a MAP sensor which means you also need to buy the XS Loom... Presuming you want to ditch the AFM. Given the ViPEC comes with the IAT sensor and on-board MAP sensor, the initial outlay ends up pretty close. Just food for thought.
Edited by Hanaldo
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
