Was raising car up a bit today and noticed that my rear left camber arm is fouling on the coilover. I have attached pics.
I had the car wheel alignment done not too long ago and when they fixed the toe on the car rather than use the adjustable arms to fix it they adjusted it from the hicas lock bar instead. Is that what has caused this major misalignment compared to both sides? You can see the toe arms are adjusted very differently to eachother but the car drives straight.
I have looked and have not broken anything the car drives fine and I actually did a drift night when it was like this (I hadn't seen it) which makes me think it may actually clear more when weight is put on to the car but it's obviously something I would like to be correct.post-67189-0-17973800-1377572406_thumb.jpgpost-67189-0-70095300-1377572425_thumb.jpgpost-67189-0-23511100-1377572455_thumb.jpgpost-67189-0-33796100-1377572471_thumb.jpg
https://www.sau.com.au/forums/topic/430903-rear-camber-arm-fouling-help-please/
I think you, and possibly the wheel alignment place, are getting confused about what arms do what. The rear toe arms, coming from the hicas rack, affect static toe. The rear camber arms affect static camber. The third arm, the traction rod/arm, affects dynamic toe/camber. Meaning, it affects how the toe/camber changes under compression and rebound.
What brand of arms are these? Surely there must be a massive amount of bump steer in the rear end? I suggest taking it to someone who knows what they are doing.
Just the arms that Option 1 Garage sells. Haven't ever had any issue with them till I noticed this. I just adjusted the traction rod and it has given me clearance from the coilover now so I believe my suspicions were correct.
Going by what White GTS-T has said it must mean they adjusted the static toe too much and didn't adjust the dynamic toe which was off between the two sides. I was there when they did the alignment and know that they did not touch the traction rods when they did the alignment
To concur with what has been posted above....look at the 2nd and 4th photos. The traction rod is much longer on the one that interferes. You can see how much "rusty" thread has been exposed by it being adjusted to a much longer length and this is almost certainly the reason why the camber arm is rubbing on the damper. Shorten it to about the same length as the other side and then get a wheel alignment, per above recommendations.
This is what I ended up doing. I will still hit up the alignment shop to have a look at all the arms and get them to adjust accordingly by a professional
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
