Hello SAU..
Regretfully up for sale is my r32 skyline.. This car has been mine for the past 2 years and am the second owner in Australia. Has always been serviced every 5000km with regular oil and fluid changes along with many upgrades and tidying up.
Year: 1990
Make: Nissan Skyline
Model: R32 Gts-t
Kms: 145,000
Rego: November 2013
Transmission: Manual
Colour: Black Pearl Metallic
Modifications:
  • Has had a R34 RB25det NEO transplant which was only done January last year and running standard boost
  • Timing belt was replaced when motor put in
  • Nismo engine mounts, Solid rear cradle mounts
  • Custom stainless steel dump pipe and full 3" Apexi exhaust system
  • New Clutch master cylinder
  • NPC heavy duty cushioned organic button clutch
  • Walbro 255L/hr fuel pump
  • 40mm triple core alloy radiator
  • Rota Grid wheels with 90% tread on all 4 tyres
  • r33 gts-t 5 stud brake and hub upgrade
  • HEL braided brake lines
  • SRI adjustable rear camber arms
  • TEIN Mono control master coilover (height and damper fully adjustable)
  • upgraded r33 diff
  • r32 GTR front mount cooler with custom piping
  • r32 gtr bonnet and carbon fibre grill
  • r32 gtr front bar (fibreglass)
  • custom power steering cooler
  • custom cold air intake
  • rear guards rolled
  • gearbox recently serviced with Redline lightweight shockproof oil
  • CD player with USB & bluetooth connectivity, front and rear splits (sub + amp was removed but can be inc)
Other: AC removed, Hicas system removed (inc solenoid and lines), speedo cable snapped..
Extra: Alot of money has been spent on conversion and no shortcuts were taken, very nice car to drive, solid and straight, new owner will definatley be pleased !!
Price: $9500
text Nathan on 0423 459 086 or PM for details etc
Can inc following items for additional cost decided on settlement
  • driftworks total hicas eliminator kit (BRAND NEW)
  • GReddy Profec boost controller (BRAND NEW)
Edited by nath101
https://www.sau.com.au/forums/topic/430924-r32-skyline-rb25neo-for-sale/
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
