Just did some research on Nissan Techline and discovered the following:
  • Techline Consultants work within the After Sales Department
  • Employed by Nissan Motor Company Australia
  • Provide diagnostic & consultative support to the Nissan Dealership Network
Techline Consultant Key Responsibilities:
  • Delivering a professionalism process for all dealer technical issues & support the dealer network in delivering the highest levels of Customer Satisfaction & Fix it Right First (F1) time initiatives
  • Assist the Technical Training to Design & Develop training material and communicate with NML regarding Technical publications for the Australian market
  • Support the introduction of New Models and the unique technology through the supply of technical support, rectification & process control
  • Assist in the management of vehicle product problems - identification, investigation, definition, reporting, follow-up, dissemination of information and explanation
  • 2 months later...
Getting in contact with techline is almost impossible through any GTR dealer in WA. FFS Nissan
  • 4 months later...
On 3/30/2015 at 4:28 PM, charlie200 said:
For those NZ folks... I'm going to attempt the firmware update in Auckland through a GTR accredited Nissan dealer. I've been living with the low rpm lurch for a while now and isn't too big a deal, yet. Will be interesting to see how it goes - there's a tonne of these around town now so surely i'm not the first to approach them with this.
Im guessing you never got anywhere with it? I ended up selling my V36 because the lurch pissed me off. Its a shame, they are such awesome cars.
Hey @awsam,
Trust your supper problem is long gone now. However, how much reduction in power is experienced ? Any detail you can share will be great.
Thanks mate.
How did your firmware update go @charlie200?
Cheers
Edited by Elcid
spelling
31 minutes ago, Elcid said:
Hey @awsam,
Thanks mate.
Cars been a dream since.
Slight delay in the milliseconds off the line and the point at which it changes gears is slightly different from memory.
  • 1 month later...
On 21 May 2014 at 8:10 PM, awsam said:
It's almost been 2 weeks after having the update applied. The car runs 90% better, which for anyone who has the same problem is incredible!
The grunt is still mostly there, and the acceleration delay feels 50% reduced. There is no more bucking, hiccups or stuttering. A couple of times i've felt maybe 3 small bucks (like 5% of previous strength) at low gear, but only ever once while driving.
There is no more hesitation from a stopped start at all.
The anti slip control seems to be less sensitive now also.
I highly suggest anyone experiencing my issues with a 2008 V36 sedan have the update applied, even if it's just so you can sell it for more. Main North Nissan charged me $190. If you're in Adelaide, ask for Josh.
Andrew Taylor from Infiniti Melbourne was the man who made it all happen, top guy, went above and beyond for no reward other than the gratitude.
I'm so happy it's fixed, so incredibly happy. Now we can actually sell it for what it's worth :P
How can I get this update in Sydney?
who do I go to?
ive asked Infiniti Sydney and they said they can't do it and I've asked a couple of other GTR dealerships and they also can't do it.
who do I go to?
Don't know what else I could tell you that might help.
Im in adelaide, bugged Infiniti Melb for a while. They facilitated getting the update from japan. Which was meant to be sent to Adelaide. Nissan refused, instead held the update and sent it to TECH LINE. GTR dealership in Adelaide connected a laptop to my car. A person from TECH LINE in sydney did the update/config remotely.
Andrew Taylor from Infiniti Melbourne was the legend or helped me out in 2014.
If I send you a cable, would you be open to taking a dump of the ECU and send it back to me? You'll need a laptop with Windows on it.
  • Like 1
So I managed to get some info on throttle body programming which can potentially resolve the issue. Is that what you had done awsam?
Also do you know the number for techline Sydney?
  • 5 months later...
Tried contacting josh Kolinac from main north Nissan. He replied and said he was going to have a look as the update is stored on an older consult which is now with their IT department. But now he hasn't replied in almost 2 weeks...
stuttering issue is getting worse
On 12/03/2017 at 5:49 PM, awsam said:
Give it a week and call em.
You haven't had any issues since the update right? He kinda scared me a little when he said they don't take any responsiblity if the patch damages the car. How could it possibly damage the car?
Still have the car, haven't had a single problem since.
They told me the same thing. At that point my V36 was near undrivable, and i'd never be able to sell it so...
They told me they hooked it to a laptop, and someone from Tech Line configured it remotely from Sydney. Beyond that I have no other info for ya.
10/10 would do again.
  • 1 month later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
