Hey guys so after contacting the dealer that AWSAM got the update done at, I got the details on the update. He said to tell your local dealer to Contact Nissan Australia tech line department and refer to IQ contact 890008
so I did this and went in today to get the update applied to my car (2007 V36 sedan) and it turns out they couldn't download the update to my car for some unknown reason. So I don't know what the go is but I'm gonna give them a ring again tomorrow to follow up. I had a quick thought that maybe the update has already been done on my car in the last before buying it but then I thought it couldn't have because otherwise I would'nt be having the stupid bucking/stuttering and hard shifts that I get in my car... ?
Edited by moleman_1
  • 4 weeks later...
Ok so I managed to solve the issue!
It was a fuse that was missing in the fuse box in front of the battery. The fuse is named 'anti theft ACC' it's a 10A fuse.
The fuse was actually missing from my car for some reason...
So I popped a 10A fuse in there when I seen it was empty just because I thought it needed to be there since it was pretty much the only one missing and then when I took it for a drive afterwards I noticed it didn't stutter like it usually does. Now I've taken the car for a drive a couple of times and haven't noticed the stuttering come back at all. So it must've been the damn fuse!
  • Like 1
As much as I hope this is a fix, I have doubts.  I checked mine and while the fuse is also missing, there is only one terminal post for the fuse.  Therefore putting one in place in my car would do nothing unfortunately
Edited by Rufus007
  • 5 weeks later...
You're right it did nothing. I read the other thread about it's probably the VTC being the issue. Did you manage to get a fix for yours @Rufus007
I reckon it is the VCT being sensitive to oil used.
I had Penrite 10 tenth in the car for a period of 5000km and it had the stutter at random times - cold, warm hot...
Change to Mobil 1 Extended Performance 5w30 - not a single stutter
2007 V36 sedan with 50,xxxkm
Can't hurt to try on the next oil change
Hi guys, not sure if it was in this thread or another thread but the this issue is a tuning issue where the exhaust cam phasing is too aggressive. Some of the Z33's that runs the VQ35HR have the same issues. There are a few tuners from UK and US who knows of the issue. One of them quoted this
"We see a problem on these car mostly at part throttle which is caused by the exhaust cam control issue , basically the PID (closed loop) is too aggressive and causes the cam to move too far causes a stutter it could cause the same issue at cold warm up I presume if it is using the same part of the exhaust cam map."
To test his theory, I set my exhaust cam phasing settings to 0 and I don't get any of these issues at all. This is of course a band aid fix as this means I won't be utilising cam phasing at all. Will need to get a tune done with someone who understands cam phasing and test how far we can push it. I could be totally wrong though...
How long have you been running the Mobil oil for?  I find whenever the oil is freshly changed there is no stuttering with any brand / type etc.  Strange, but the stuttering then comes back soon.  I've had best ongoing results with Castrol edge 0w40 (density 0.841) iny car tho.  If you read some USA threads apparently lower density helps
Been in for 3000km now with no stuttering.
With my car it didnt like the 10 tenth oil. Stuttering happened not long after.
  • 1 year later...
So @moleman_1,  did you follow up on why they couldn't do an update on your car? I believe there should be a firmware version or something similar they can check / read out to tell if the fix has been applied to your car prior ?
Had a nice long chat on the day as to why they couldn’t do it. Apparently the file wasn’t able to be applied for an unknown reason, they couldn’t tell me why, probably because they actually didn’t know why... Nissan are quite useless and all they want is your money, that’s what I gathered. So now I gave up, unless someone else has an alternative solution?
If they can copy what they need from my car and apply it to yours, i'll take it down to Main North Nissan for you.
  • 2 years later...
Interesting that the Plenum bolts solved his issue : https://g35driver.com/forums/engine-drivetrain-forced-induction/340934-hesitation-bucking.html
Thought it might be of interest in case some have not solved the issue.
FYI - My (newer, second) 2007 G35 does not have this issue.
  • 1 year later...
Hello guys
hopefully I can get answer after I really spend a lot of money for really nothing
I know I am so late for that , after looong time researching I don’t know how all this time I didn’t see this thread!!!!
Please note that my oil pressure is after fully warm up is around 8-10 psi / 2000k rpm around 40psi / cold start 80 psi
now I have all above symptoms and I have confirmed that
I did these 4 tries to confirm what all of you said
These results confirmed by driving long distance with every try just to confirm the results
1 - disconnected both sides = issue gone
2 - disconnected right side only = issue gone
3 - disconnected left side = issue gone
4 - plugged both sides = got the issue back
Really want to confirm before I waste more and more money
I know the gallery gaskets needs to replaced but for now ,This sputtering will be fixed after I replace this vtc or the oil pressure will be the main issue? , I know and saw in groups some guys their oil pressure is less that 8 psi and they don’t have this sputtering
if the replacement will fix , do I need to replace both sides full covers assembly or just the variable valve timing solenoid
is there any possibility of any other warn parts effecting the vtc functions like bad pcv valve or others
  • 1 year later...
Yer Nissan basically told me to get f**ked on my V37 firmware or any update for that matter.
Basically Private/grey import and is not released in Australia and No Parts can be offered in Australia to fit or any software upgrades or something to that nature.
At the time, the most help I received was actually from Infiniti Melbourne. They sourced the update and provided it to nissan, and then Nissans Techline applied it remotely. Andrew Taylor from Infiniti was the legend behind it all, along with Clint Robertson.
This was a long time ago now, you could try is email Andrew_Taylor@infiniticars.com.au and ask him about the 2008 ECU update he helped facilitate in 2014.
If you do speak with him, let him know Im still incredibly grateful for his help.
  • Like 1
