Experienced this once on my other car. It was a dirty throttle body..
Felt it too on my friends turbocharged vw and corrolla... seems normal though. Slight stutter on acceleration from stop.
doesnt happen on my 350gt. Im hearing enough loose panels in the car :rolleyes:
Just putting my 2cents worth
Hey mate i have this problem as well in my car when i put car into drive from stationary to drive,or drive to reverse it gives a jerk.Sometimes while driving the car it gives stutter for about 2-3 seconds above 1000 RPM,Car is back with dealers to get it fixed clearly explained them if they can get this fixed more than happy to get that back otherwise dealwith them in other way.So the salesman at the caryard is keeping me updated what's been going on i just recieved text this evening saying they have cleaned the throttle body and car is booked in for throttle soft wear RESET I Dont know what he meant with this RESET.If u got any idea could you explai.
Cheers
They cleaned the throttle, and now it's probably worse, so you are paying for them to do a throttle re-learn now, that should have been done in the first place imo. It's a 10 minute job with the Consult reader, so don't let them charge you through the nose...
My last mechanic told me he couldn't connect to my car using consult because it was configured to speak to his 2x R35GTR's only, does that sound legit?
as car is under 6 months warranty but it has got too many problems lkike when engine is hot,we turn car off and start it again it makes a clap sound from dashboard,i changed the factory wheels with 18' aftermarket after two weeks front suspension started making noise,stutter problem,engine mobiliser goes on when its bit windy which christchurch weather is always like that too annoying.Car has been brought from one of the reputable dealers in christchurch but there service has been shocking it has 6 months dealership warranty.I bought this car about 3.5 months ago from this time period my car was at dealers about 4 times roughly a month ??
Any advise wat to do further ??
Forgot to tell ya they imported this car for me from japan,when car arrived here in nz it had acid rain in paint (Roof,Boot lid).Right side doors were all heavily chipped.Bonnet was heavily chipped as well,I had to fight for this to get it fixed as i picked up my car on rainy day so cudnt see any paint blemishes.When i washed my car 1st time i saw all this shit.Car had very little brake fluid,took it back to them dey started saying its white paint on my car which they cudn't see it was acid rain.
Then other thing brake pedal pulsing,after another month,All the door lights,dome light,retractable mirrors stopped working.Car was at dealers again to get this problem fixed
mate you've had a shocka :-/
I think so as well but if my car is not right this time wen i go to pick it up as per Consumer acts i am gonna get money back dats it cz i hve had enough of it already in last 3 months
Dump it, this car is a total lemon
Hopefully tomorrow I get good news from Infiniti.
I'm worried though that the firmware will not fix it and instead its a "Oil gallery gasket" ?? Is that just a oil pan rubber gasket?
Edited by awsam
There are a few Orings they could be talking about, some in between the sump and block, some between the block and cam chain cover.
Unplugging those solenoids a couple of pages back is unlikely to make a difference to the affects of a damaged O-Ring/gasket?
Edited by awsam
It will stop the units actuating. At a guess if the advance/retard mechanism is banging the end of it's travel then the Orings will be fine, it will more likely just need camshaft degree reprogramming. There is a menu dedicated to cam actuation diagnostics on the consult 3. Things like oil viscosity and oil pressure will change the requirements for cam control away from the factory settings enough to require reprogramming of the pwm signal. These engines learn to some extent but there are definitely re-learn procedures your mech can try.
Failing that, I have heard of the hydraulic solenoids getting blocked inside, there is a fine gauze filter on them. If you are having problems with the electronic actuator though, then you may need to replace the advance/retard assembly as I mentioned earlier. Quite a common fault on the VQ25's.
Thanks for the extra info, sounds like more work than anyone I've come across in Adelaide is enthusiastic enough to investigate.
I really wish I could slap a bandaid on it and just f**k it off lol.
Hopefully Infiniti have finally got an answer for me tomorrow morning.
Infiniti just got in touch, they've finally been given permission to discuss the logistics with the department handling the update in Japan.
Yea mine is booked in for tommorow at Nissan dealership as well for ECU update and Throttle reset lets see what happens next fingers crossed
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
