I'm just about to do that, too... In my Berlina, it was just a case of splicing into, or making an in-line adapter from the sensor wire, then hooking up positive and negative power.
On the Skyline, there are three cables for the oxy sensor, use the single wire that is not the same colour as the other two. I think it is white, with two blacks for the heater. I just bloody changed mine, and I can't remember the colours!
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1687635
OK, so for my O2 update;
Just put in the NGK recommended sensor, which has the right plug on the harness.
When I run SRTalk with my consult cable, the O2 readings aren't jumping all over the place like the ROX207 one did.
I will have to see if it still does that after getting quite hot, and i'll let you know my fuel economy (Stan, don't miss it!).
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1687642
I summarised all the part numbers for O2 sensors from a non-current version of FAST in http://www.pcug.org.au/~jdeakins/facts.html
There are:
two part numbers for the 08/93 to 11/93 R33 RB25DET,
two part numbers for the 11/93 to 01/96 and 01/96 to 11/97, and
two part numbers for the 11/97 onwards.
Noice website. Was there any explanatory notes for the parts? Sometimes parts get deprecated, hence more than one part number.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1688566
  • 3 weeks later...
ok, ive just read through this whole thread and lots of very interesting info. thanx to all.
i curently am getting no more than 250km to a full tank, and its been this way for over a year.
im talking 250km max, average 200, 210.
anyway, im convinced after reading this its my 02 sensor. im gonna go pick one up in a n hour or so.
only thing im not usre about is what to do because i have an apexi power fc and not the stock ecu. i heard that the ecu requires resetting but this is not possible with the pfc.
can i just change the sensor and let the pfc take care of it self? as i cant afford to take it to get tuned again.
thanx in advance.
ps: im going for the ngk sensor, if i can find it.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1737331
AutoOne can order them in for you, using the code from the NGK website. As a few people pointed out, your sensor may not be dead, and I suspect that is the deal in my case.
I wanted to change it anyway, as it looked to be the original unit. I haven't touched the sparkies yet.
I get 350 to a tank now, pretty consistantly... so... slight improvement? I think it'd be interesting to know what most other people without a problem get to a tank. A couple in this thread said 400-500 per tank... but is that normal? What size tank? Which fuel and what mods?
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1737590
well i just got back from repco and they reduced the price for me of the ngk one to $100, orginally $159 they said. anyway, it'll be in tomorrow.
for the record my mods are:
3" exhaust turbo back
apexi power fc
dual boost controller (btween 7 and 14 psi)
pod filter
front mount cooler
and no cat
i am still waiting to hear if my pfc will pick up that the 02 sensor is new, or if their is anything i need to do.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1737649
I phoned Petroject yesterday and was told that a universal 3 wire O2 sensor was $105 plus tax. I quoted the part number 23011 as skypy12 said early on but the guy didn't seem to be able to find it.
I went in today to buy it, but the guys working there didn't know who I spoke to and so I had to start all over again. I said the guy had told me about a universal fitting one but the new guy said that they were all different and he had no definite one for an R33 GTS-t. He brought out a couple of which one he was fairly sure would fit and I tested my memory of the old plug (which was still in the car at home).
Through my memory of the old plug I worked out that it was the large thread, zirconia, male plug, with 2 white wires and one black. The only other possible one he brought out (3 wire, large thread) was titania and I therefore deduced for a GTR, so that made me doubly sure I had the right one. I got the medium length cable version because that's what he brought out, but I'm fairly sure that the short length one will be fine (it was what my old one is anyway).
The part number on the end of the box was 23109, so perhaps the 23011 above is just the short cabled version. If in doubt just take a look at both and compare and see if they're otherwise the same, and you can get either one. This for a '95 R33 GTS-t anyway. The biggest disappointment was price, it was $160, although only $110 trade, so if possible get your mechanic mate to pick one up! I think maybe the $115 one I was quoted on the phone wasn't an NGK, or the extra few cm of wire cost $45 (!?) Or maybe he accidentally quoted me the trade price (which would have made it $5 more expensive... hmm)
I also spoke to the guy about some rumours I've seen around both here and elsewhere. He said that you don't really need a factory sensor to get the best efficiency, because they are all very close in tolerance, and almost all of them are made by one of three OEM's anyway. They being Delco, NGK/NTK, or Bosch. If you wanted the "closest" one to factory spec, then get the same brand that made the factory one I suppose. The guy said that NGK was probably the best quality brand, but they sell all three brands aforementioned. I don't think it matters at all unless you're running a completely stock Skyline, which very few of us are!
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1741590
Last weekend I drove my R32 GTR from Canberra to Sydney then back.
I was using Optimax and was driving carefully but not slowly - I wanted to see what sort of economy I could get. I managed:
11.54 L / 100km (20.38mpg) on the way to Sydney (downhill), then
12.06 L / 100km (19.51mpg) on the way back.
That's still not as good as a Commodore :O, but it works out to be just on 700 km per tank of 80 litres.
I normally get around 400 km driving around town, but fill before the light goes on.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1747535
Just hop on the ngk website and search the database for the factory 02 sensor. They are around $100 and should be in stock or can be ordered in a day or two. The NTK ones fit perfectly and work great.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1750094
DO NOT USE THE OZA23-D2 sensor!! That is the FORD EL one (despite plenty of 'it works' in here)
I've been running one on my r32 for a couple of months, and it simply doesn't work as it should.. voltages at warm sit at 1.35v which is NOT the factory. While sure your car will sure, run, its next to useless as its not behaving like it should.
Its actually worse than having your oxygen sensor completely disconnected, where it goes into "limp" mode and sits at 0.3v... and the ecu just acts in failsafe for closed loop operation.
Checked all this via the consult connector and my laptop.. so I've only recently been able to check properly.
You've been warned..
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1773697
I used one of those in my redtop rb20dets in my R31 and the car wouldnt even idle below 1500, misfired, no power below 3. Once you put the boot into it it was fine but yeah had to unplug it straight away. Im pretty sure the earlier redtop sensors are a different type to the EL ones as the EL one was white white black and the stocko one was red black and white.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1774072
apexi power fc
pod filter
front mount cooler
and no cat
Thanks for the info. How many k's to a 50L tank do you get before the plug-change? I'm lucky to hit anywhere near 400km's in a pretty stock R33. I only get close to 400 if I do a LOT of highway driving.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1775630
I've read all 21 pages and unless I missed something I didn't see the confirmed info that I need.
For an R32 GTS-T w/RB20DET, could someone please tell me some "FACTS" regarding O2 Sensor part number, price and place of purchase ?? I want one that is a direct replacement.
EG.
Brand: NTK, P/No. OZA395-E2, Buy at REPCO, $145
Thanks.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1791792
yes, Nissan does. Don't be lazy
Gee thanks..... Your helpfullness is astounding !! And I'm not lazy, It's just a lot easier to call up & quote a part number than it is to get them to go look it up. If anyone asked a similar question I'd be ( and HAVE been ) happy to provide any info I could.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1792081
Thanks to those who have PM'd me with the part number !!
For those of you who might need this info in the future it is:
O2 Sensor to suit R32 GTS-T w/RB20DET is NISSAN P/No. 22690-73L11
I've called NISSAN and I believe there are none of these in Aus so I'm going to order one from Japan.
https://www.sau.com.au/forums/topic/43095-o2-sensor/page/7/#findComment-1792234
    • Splitfire Nissan RB Twin Cam Street Series Splitfire Coils. Basically brand new less than 10kms use. Only selling as ive upgraded to the IGN-35A coils $400 price pretty firm
    • We have 2x Swifts and my plans for a Swift, unfortunately, do not extend to an intake and an exhaust. I've been having dirty thoughts about a 2.5L Suzi V6, AWD gearbag out of a suitable donor, rear floorpan graft to take the rear cradle from same, and either trumpets of evil or a small supercharger. If I'm going to make noise in a Swift, I want it to be anti-social, evil handling and rough. Probably need to be fully stripped inside, matt black paint, plastic windows, 7" wide wheels, big brakes, silly suspension, etc etc etc. I have no idea if any of the proposed driveline components could take the pain. But it would be a hoot finding out.
    • Really, anyone modifying a car isn't being financially smart. We're doing it for the things we love. And honestly, a high revving, light, NA car is actually pretty darn fun. I used to have a Swift Sport, and I miss that thing as a daily, and yes, doing something like some intake and exhaust stuff would have made minimal gains, but would have bought an even bigger smile
    • We are taking pricing back to 2022! The skid pan is nearly double the size of avalon so much better for longer battle runs as seen here > https://www.youtube.com/watch?v=ANxdRf3Do2s When: Saturday 14th June 2025 Where: Winton Skid Pan (Winton Motor Raceway) Price: $145 for SAU VIC Members            $199 for non Members Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to motorsport@sauvic.com.au or print and hand in and Driver Sign In. email motorsport@sauvic.com.au To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Accommodation:  In an effort to try new things and support other country towns we thought a new location for accommodation was worth trying and Euroa was great last time plus its 30 minutes closer to Melbourne. Saturday night we will book a spot at the pub for a couple of quiet drinks.......   Book your accommodation ASAP before it sells out, there are also other options in town if you want to stay elsewhere and join us for dinner Saturday night.   https://euroacaravanpark.com.au/ Address: 73-103 Kirkland Ave, Euroa VIC 3666 Phone: (03) 5795 2160 Entry link with Full Supp Regs to read: https://www.sauvic.com.au/entry/deca/20250614 Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email motorsport@sauvic.com.au Entry List: 1. Josh M 2. Anna 3. Luke  4. Katie 5. Martin 6. Tony 7. Alix 8.  9.  10.  11.  12.  13.  14.  15. 16.  17.  18. 19. 20. 21. 22. 23. 24. 25. 26. Reserve List 1. 2.
