Well the NGK connector is light Grey and more solid looking with all the spade pins Vertical and positioned in the center of the connector. The R34 or BOSCH connector is black, maybe a fraction smaller and all the spade pins are Horizontal and thinner and positioned in the top area of the connector.
Might take some shots if I get around to it...
I haven't read ALL the posts in this thread so don't know just how expensive the Bosch sensors are but I just wanted to get mine done so got a genuine one through Nissan, took a week and $180 bucks.
probably not the cheapest way to go but took about 10 Mins to change over. Borrowed a mechanic buddy's O2 tool and the sensor came with correct plug and even the wire clip down thingy.
I can help with genuine Nissan R34 GT-t sensors for $176, and NTK R32 GTS-t & R33 GTS25-t for only $77. For full listing just check out within our trader section:
http://www.skylinesaustralia.com/forums/Nt...so-t135194.html
did mine on the weekend.
plugged the laptop into the car and found one o2 sensor stuffed. rang nissan up and wanted $225 each per sensor, and 2 week wait from japan.
or $98 each from auto1 but with rewiring and $60 for o2 sensor socket ( makes life a lot easier).
plugged laptop back in and reset ecu, and sensors are working. now just need to see how much better fuel economy is is like.
Mr Moo - you could have bought that NGK one for 80 odd and changing the plug over requires only 2 basic tools - something to cut with - and a pair of pliars to crimp the old and new wires together using about $1 worth of crimps - they ripped you off charging $60 to cut and join 3 wires!!
Bloody hell I install an entire xbox mod chip for that price!
In fact you only need one tool as pliers can cut as well!
R33 GTR sensor (front at least) is a Bosch A24-621 115 68290
Global Auto Spares Part Number 351-0187
Same sensor for the rear, only lead length and plug differs.
Needs a 22mm spanner
18mm Thread - 3 wire Oval plug on a short lead - Titania
http://members.pcug.org.au/~jdeakins/facts.html helped me find what I needed
Global Auto Spares on the coast imports them
Chris Jeffis
0755310055
[email protected]
Hope this helps some people
I just rang GLobal Auto Spares and spoke to Chris. He said that Bosch no longer sell the sensor with Global Auto Spares numbers 351-0187. Apparently the alternative is 351-0040. He said he just sold them to someone else. I told him it was a R33 GTR (or 260RS) and that it has a larger thread that the R32 and he said "yes, that's correct. We have the right one for you". Seemed like a nice guy and seemed like he knew what he was on about. I have ordered 2 of them. They only cost $77 each. I'll let you all know how I go. James you may need to update your website.
OK. The table is now updated. Did it have a Bosch number on it? Let me know if you ran across any problems.
BTW - if you want the table updated you should use the email link on my page. I don't visit SAU all that regularly any more. I'm always happy to receive updates though - especially the more obscure models. Keep them coming!
James
James
They arrived yesterday, but wife didn't pick them up from the Post Office. So hopefully I'll have them tonight and can let you know part numbers and if they worked. I'll use the email link in the future. Didn't notice it. Sorry
Well I just opened up the O2 sensors. The brand on the pack says "Global EFI" with part number 351-0040. The plug looks a lot like the front R33 GTR one. The part number on the sensor is OZA395-E2 KBA16693 and it says that it's a NTK sensor. I'll let you know how it goes when I install it.
Hmmm I need to look into this further. A quick flick through this topic shows that people have listed this sensor as an RB25 one. It looks like it's Zirconia and from what I've read the R33 RB26 one is Titania. I'll see what I can work out from the stock one.
Well I just went out and had a look at the car (Stagea 260RS - R33 RB26DETT)
-The O2 sensors have a much wider body than the new ones
-The plug on the new one matches the front sensor perfectly
-I couldn't really make out the numbering on the stock sensors, but it looked like a standard Nissan part number.
-I am definately gonna need one of those tube sockets :P
From what I've read in this thread, the R32 GTR sensor is definately Titania. A few people have mentioned that the R33 GTR sensor is also Titania. Can anyone confirm this for sure? I did a search for Bosch a24-621 which apparently was the previous replacement that Global Auto Spares used to sell. I couldn't figure out if this sensor is Titania or Zirconia.
I think I might give Global Auto Spares a ring tomorrow and ask him about it.
The latest on this hunt for R33 GTR sensors.... I just rang Global EFI and Chris has been looking for a Titania sensor with the large thread size that the R33 uses. He says he hasn't been able to find any. He has contacted Bosch who had nothing and he is still waiting on a reply from NGK, but is not hopeful. He said he is able to get R32 GTR sensors no problem, but they are a small thread size. Does anyone know if there is some sort of adapter to mount the small sensor in the larger hole? I'm gonna do a google search.
BoostedBarge, I am not at all sure about the titania vs zircon sensors, but I am 100% sure that the 32 and 33 gtr looms and ECU are interchangeable - which means that the signal they output must be similar enough to work from either type of sensor if they are different between 33 and 32. Keep in mind narrow band o2 sensor is a very simple beast.
Part# I posted earlier is what you need...
ngk part # for r33 is OTD2F-P1P. direct fit for front sensor (3 pin plug).
Get 2, change the plug on the rear one.
THanks mate, the problem is finding that sensor for the 33. Global EFI rang Bosch and NGK and didn't seem to have any luck. I'm thinking of using the R32 sensors with an adapter to make them fit. I'm pretty sure that my old GTI-R had an adapter from the factory, because it used a small size O2 sensor. Maybe I could get one from Nissan or a wreckers.
If your running a PFC you can flick between the zirconia and Titania calibration.
I can confirm the calibration is completely off/different between the two so there's no way you can get one working with the other calibration.
Only issue is the plug. :laugh:
Sorry, I'm still running the stock ECU :P
I just had another look at the O2 sensors... I don't have the socket to remove them yet, but using a mirror and my digital camera I was able to work out it is a Bosch sensor and has the number "A14-A21 141 ....." on it. I did a Google search and found this
http://www.trademe.co.nz/Trade-Me-Motors/C...n-169217176.htm
which confirms the rest of the part number A24-A21 141 63072
I found on another forum that someone said that the R32 is Titania, but the R33/34 uses Zirconia. If he's right, then I might be in luck. I'll give Global EFI a ring tomorrow and see if he can find out if that part number is for a Zirconia or Titania sensor.
Oh yeah, if anyone has a spare sensor lying around, I'd really appreciate if you could confirm the part number for me.
Simon
My R34 had:
LIC. BOSCH A24-A71 047 87280 but it is a RB25DET if you have the RB26DETT then you will have to use the Titania ones. the single turbo ones are all Zirconia...
NGK / NTK OZA395-E2 $85.80 was my replacement part which should work for both R33 and R34 (with the plug swapped on the R34)
Tool used was a standard 20mm spanner. The thread was 18mm from memory. Use the spanner on an angle as there is not enough room between the firewall and the exhaust pipe, and the engine and some other box thing... - so no special tool required
Click here for the NGK part
I rang Global EFI and they said that since the sensor has 2 white wires and 1 black, it is most likely a Zirconia sensor. He reckons he just sold a couple to a guy who owned a R33 GTR, so I'm just gonna go ahead and see how it goes.
The part number didn't help at all, because he thinks it is a Nissan number.
Also, I just purchased an O2 sensor socket for $22.50 from these people. I confirmed it was 22mm.
http://www.toysforboys.com.au/products/1-o...sor-socket.html
I asked at Repco and they said it would be $60!
Only issue is the plug. :thumbsup:
How do you do this? Is it only in datalogit or can you access this from the hand crontroller.
For those with large dia bosses for small dia sensors, I picked up a pair of adapters from the local exhaust mob for about $35, screwed straight in. Pity that one of my original sensors looks like it didn't like being removed and replaced, or was dead previously without me knowing.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
