  • 2 months later...
I tried a new thermostat that opens at 71deg, no noticeable difference on economy... did get 320km 2 weeks ago,
but i recon that was due to the freezing cold weather / denser air.  I'm at 18-19L per 100km.
The idle felt a bit softer with different thermostat, so adjusted the aac screw a 1/4 turn to the left, idle feels better.
tested the old thermostat, started to open at 78deg, fully open by 86deg, about 4-5mm gap.
Also i recall my natrad radiator was about twice as thick as the standard radiator.
Fuel filter has also been replaced in last month or so + oil and oil filter
Replaced the charcoal canister hose that runs back to the rear of the motor as it had cracks.
Replaced the blow of valve rubber hose, as i wasn't confident that it was sealing properly.
Replaced 3inch hose on the throttle body / intake which was rock hard, im sure it wasn't sealing correct.
Pedal feel is better, will post in a week or so on the km.
I got 358km so far and the fuel light just come on, fair improvement over pushing to get 300km.
I attribute this more so to fixing the hoses. I guess the 02 sensor, helped a bit + cold temps of late.
Have reverted back to the original thermostat today and re-tweaked the aac valve screw to correct idle speed.
Will post up again if any dramatic results.... hoping for 400km a tank :)
Edited by Stagea_Neo
  • Like 2
  • 3 months later...
Never got the 400km out of a tank, above was best result. Also that was with the boost solenoid mod :).
Without the boost solenoid mod fuel consumption got worse again, I guess 8psi approx is a sweet spot.
Also I recommend if you haven't swapped your spark plugs ever, like me until today, definitely check em
found two not tight affecting compression, in turn economy and they were just old as.....
  • 1 year later...
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
